mtflight
09-26-07, 01:38 AM
History:
had the car for 2.5 years. 107K miles 98 Eldo Touring, relatively trouble free.
The ongoing problem:
Intermittently (about 10-20% of the time) for the last year and a half I would have a difficult hot start, what I mean is let's say I go to the grocery store after work.... when I come back 45 mintues later and I crank the car, it does not ignite unless I hold for a few seconds longer.
This would be a symptom caused by the FPR, fuel pressure regulator--but I have pulled the line off the FPR nipple when the car is running and it's dry. I've also tried putting a vacuum on the nipple both with the car off and on and get no fuel coming out, and no loss of vacuum...so thherefore, I have not replaced it (yet).
Recent New Variation To the problem
For the last month I have had a new symptom, presenting itself at the same time the hard hot start occurs (i.e., not in the morning when the car is cold, as then it fires up like it's brand new, but only when the car has been operating and is parked for a few minutes to an hour and even then it does not happen ALL the time).
The new symptom is... as it does not start while I hold it in the start position... it eventually fires up (then runs fine) along with the Check engine light :helpless:
I pull the codes while the car is on and I get 3
DTC B1910 CURRENT:
Generator L-Terminal Open Circuit
Circuit Description
This test is performed with the ignition switch in RUN, the engine speed less than 400 RPM, and the vehicle diagnosic system not activated. This DTC indicates an open circuit in the Generator L-Terminal feedback circuit. The generator grounds CKT 225 when the engine speed is less than 400 RPM and the ignition switch is in RUN.
DTC Will Set When:
Then IPC measures engine speed less than 400 RPM and determines that the L-Terminal circuit is open by sensing a high voltage condition at terminal A9.
DTC P1375 CURRENT:
IC 24X Reference Circuit High Voltage
Circuit Description
This diagnostic test checks for 24X signal at a logic high condition. The fault could be induced by the failure of either Crankshaft Position A or B Sensor input signal to the Ignition Control Module. Under such a condition, the Ignition Control Module would force the 24X signal high. This DTC will also set if the 24X signal is shorted to voltage externally. If either condition is met DTC P1375 is set.
Conditions for Running the DTC
DTC P1376 is not set.
Engine speed greater than 496 RPM.
At least 7 CAM pulses received since key ON.
Conditions for Setting the DTC
24X signal voltage is high and no 24X reference pulses have been received during the last 8 4X reference pulses.
DTC P1350 CURRENT:
Ignition Control System
Circuit Description
Under normal system operation when the key is turned ON and until engine RPM is high enough for the PCM to control spark, the PCM will open the bypass circuit (CKT 424) to the Ignition Control Module, the IC module will then ground the Ignition Control circuit (CKT 423). This is called module mode because the IC module is controlling spark. Once the engine speed is high enough (about 65 RPM), 4X reference pulses are received and no PCM faults are detected the PCM will close the bypass line and in response the IC module will unground the IC circuit, this allows PCM control of spark. This is called the ignition control mode. This diagnostic test is used to check for faults in both the bypass circuit and the IC circuit. To check both circuits this diagnostic runs two tests, one during crank and one while running. If Ignition Control pulses are detected by the PCM on the IC line while in module mode (cranking) or if no Ignition Control pulses are detected by the PCM while in ignition control mode (running) DTC P1350 will set.
Cranking Test
DTC P1376 not set.
At least 1 4X reference pulse has been received by the PCM.
Running Test
DTC P0322 and P1376 not set.
Cranking Test Ignition Control pulses are received by the PCM when cranking or running test has failed THIS ignition cycle.
Running Test No Ignition Control pulses are received by the PCM while engine is running.
So again, this coincides with the hard hot start... car runs fine and will turn on fine MOST of the time. This set of codes along the with the SES light has only come on 3 times in the last month. I can delete them all after shutting the car down for a short while. Else I can only delete the B1375 and B1910 after restarting the car (it starts up right away after turning it off) as they show up as history after a short while, while the B1350 remains current until I shut the car down for a few minutes (I can delete it the next time I crank the car).
So what is going on??? my theory is the hot start may be due to an injector or maybe the FPR, and leaving the car in the "START" mode for too long causes all the other codes to show up (as the car notices it's not starting--so it offers an explanation). HELP!!
DTC B1910 CURRENT:
Circuit Description
DTC Will Set When:
DTC P1375 CURRENT:
Circuit Description
DTC P1350 CURRENT:
Circuit Description
Cranking Test
DTC P1376 not set.
Running Test
