: 08 hookup for rdar detector?
09-21-07, 08:22 PM
Just wondering where you are getting a direct wire hookup for your 07 or 08 SRX. Any help is appreciated.
10-07-07, 12:01 AM
Noone using a radar detector here, or has noone hard wired one in? On the Corvette forums, most are using an "invisicord setup" or going directly to the fuse panel (under the passenger side footwell) to put in an "add a circuit" fuse. Unfortunately the fuse panel is either under hood or in the rear seat area on the SRX which makes it a lot tougher to route wires. That is leading me to the invisicord setup to the rear view mirror. Just wondering if anyone else has done this on their SRX???
10-07-07, 12:29 AM
Don't know about the '08's, but I hardwired to the rear wiper switch in the overhead console on my '04. Be very gentle with the plastic console cover, though, as the clips are soft, and you may have trouble getting it to stay back up after you're done.
(I had to JB Weld mine back up, but luckily, after the Ultraview switch died, dealer replaced the cover & switch under warranty--Whew!)
