toronto catera
09-19-07, 12:13 AM
bulb is fine. smaller filiment in bulb is flashing in headlight turn signal. all other bulbs flashing, other side working as normal. any ideas? i'm stumped.
| View Full Version : fast and dim turn signal toronto catera 09-19-07, 12:13 AM bulb is fine. smaller filiment in bulb is flashing in headlight turn signal. all other bulbs flashing, other side working as normal. any ideas? i'm stumped. heavycat 09-26-07, 06:20 PM Have you tried changing the bulb, i had the same problem and the bulb worked and appeared to be fine. It wasnt untill i acutally pulled the bulb out of the connector that i saw that it had burnt up the connector but had not blown. I used some electrical contact cleaner and put in a new bulb, problem solved. I seems that even a dirty ground can trick the car into thinking the bulb is blown. Hope this helps | |
