View Full Version : What Northstar do I have? 442JoeRed 09-16-07, 12:47 PM I have found a complete 1996 Northstar engine. It is out of the car. How can I tell if it is the 275 or 300 hp version? I do not have access to the car and VIN #. There is a bar code sticker on the back valve cover.
Joe AJxtcman 09-16-07, 12:55 PM I have found a complete 1996 Northstar engine. It is out of the car. How can I tell if it is the 275 or 300 hp version? I do not have access to the car and VIN #. There is a bar code sticker on the back valve cover.
Joe
look for a pad on the block just above the case joint on the back (right) side near the timing cover. The VIN will be stamped or etched in. If you see a metal tag (early production) that is the # I need to check. Yes the valve cover code will work, but the VIN is better 442JoeRed 09-16-07, 12:59 PM 6tu287070 442JoeRed 09-16-07, 01:01 PM The Bar code is: T10L441407 AJxtcman 09-16-07, 01:50 PM URBANDALE, IA or CLIVE, IA
on 11/02/2004 it had 106509 miles
6KF69 -1996 DEVILLE CONCOURS 1G6KF5296TU287070
That would be a high mile 300 hp 442JoeRed 09-16-07, 04:41 PM Thank you for all the info. It was pulled out of a rear hit totaled car about 3 years ago. Should still run. If not guess it was worth $200 for parts.
Joe mscatena 09-20-07, 01:08 PM AJ I'm in the same situation pulled a motor from a junk yard for my sand rail build, looking for more info on the origin and car
bar code T10L602646
block left side upper case seam 12554367-1
block right side lower case seam 3522506
prod plate # TU613176 (the first # looked more like a symbol "oval over an L")
your help is greatly appreciated! AJxtcman 09-20-07, 03:05 PM AJ I'm in the same situation pulled a motor from a junk yard for my sand rail build, looking for more info on the origin and car
bar code T10L602646
1996 275 hp VIN Y engine from a Eldo. strange option....UNIT SOLD FROM ENTERPRISE STOCK
It was sold from Enterprise stock to PENSKE? mscatena 09-20-07, 05:31 PM AJ you are awesome! mscatena 09-20-07, 06:03 PM any chance of getting the actual VIN for a car fax report? tsi18psi 09-22-07, 02:25 AM How are you getting this info?Carfax or sumthing? AJxtcman 09-22-07, 01:15 PM any chance of getting the actual VIN for a car fax report?
1G6EL12Y2TU613176 ------- FLEET/DAILY RENTAL
This car had never been to a dealer for any type of repairs including recalls.
Vehicle Has No Associated Claim History
It has an open recall for the fuel rail
LD8 - 4.6 L V8 DOHC NORTHSTAR ENGINE PeteAyala 09-24-07, 04:36 AM I have the complete Northstar and trans in cradle. VIN code:1G6KD57Y06U100044. I was going to put it in a 91 ETC, but I just picked up a 93 Allante 1G6VS3394PU126587 with 127,000 miles. Now I'm considering putting the new Northstar in the Allante and the 93 Allante's engine in the 91 ETC. What is the hoursepower of these engines? Any thoughts on the transplants? AJxtcman 09-24-07, 08:16 AM I have the complete Northstar and trans in cradle. VIN code:1G6KD57Y06U100044. I was going to put it in a 91 ETC, but I just picked up a 93 Allante 1G6VS3394PU126587 with 127,000 miles. Now I'm considering putting the new Northstar in the Allante and the 93 Allante's engine in the 91 ETC. What is the hoursepower of these engines? Any thoughts on the transplants?
1G6KD57Y06U100044
6U100044 Just seeing the last 8 I knew that you should not have the powertrain unit!
This VIN is for a SCRAPPED 06 DTS. It was about the 40th car to roll off the line when they redesigned the car.
The car was supposed to be destroyed:histeric: You can get someone in a little trouble. I know of one scenario that is some what ok, but The facility could still get in trouble. :nono:
oh yeah a VIN Y is a 275 hp? PeteAyala 09-25-07, 02:52 AM Wow! Thanks, I got the engine off of eBay from a company that only deals with GM parts. I went to their yard, which by the way is huge. I think they are an official GM vendor. Anyway, based on your information, I think I should keep the 300 HP in the Allante despite the mileage and go with my original plan to put the new engine in the 91 ETC, boosting the HP by 75 HP. However, if I can somehow boost the HP of the very low mileage engine to say 325-75 HP for a reasonable price I would want to put it in the Allante'.
The ETC runs strong but has lifter noise on start-up and leaks and consumes oil, possible rear main seal and blown head gasket.
When I worked at Cadillac headquaters in the early 90s I saw and rode in Eldorados that the Northstars where tested in. This cradle of this Y engine seams different from the one in the 91 ETC. I know the engine mount was updated but the cradle looks longer. My plan was to drop the old one and bolt up the Y, swap out the ECM and get a harnes extention. My concern about the cradle and desire to put a team together so I can video the project and put it on my website: http://www.beastkillercars.com, has kept me from moving ahead. In the meantime, I found the Allante. What do you think?
I will up-load new photos latter today FRAN_Astur 04-04-08, 06:03 PM I re-open this thread, I'm in the same situation bought a engine in Ebay (Germany, I am from Spain) to swap in a 98 STS, but don't know anything about this junk engine.
this is the number, 6WU733261
your help is greatly appreciated lapwizrus 04-05-08, 07:57 PM Hello everyone.
A couple of months ago I bought a used 99 Northstar that I was going to put into my 98 STS. The engine was advertised as a 99 VIN 9 Northstar with around 38000 miles. So, today I am getting everything ready for the swap and notice that the fuel rails are completely different. Well, I did some more research and it looks like the engine that they sent me might be a 96 ( and I doubt that it has 38000 miles on it).
How can I find out the actual miles and is this the 275 or the 300 hp version? I looked that another thread where a guy came up with all the info just from the code etched on the block.
Well my code is 6tu800193 and I would really appreciate any help in figuring out how many miles are on this thing and which northstar is it.
Thanks. Hi every one.
HI AJ .
I am in the same situation as most guys in this threat. I acquired a northstar engine with no infor. on it. Can you look up for me.
Block # 6VU818291 and the head cover # T10L686090
Thank you very much. |
