rollindts
09-08-07, 02:17 AM
Has anyone installed/replaced a 07 DTS head unit?
can anyone confirm that a double-din head unit will fit? (width/height)
just two basic questions i have.. also if you can provide the soundgate, pac or peripheral electronic's adapters that you used to retain the features that would be great!!!
CadillacSTS2003
09-08-07, 11:34 AM
wow
youd be the 1st to my knowledge
i dont even have part numbers for this swap
i work tomorrow at bestbuy 12-7pm EST
if you WANT you can call me at my work there and i can look you up the part numbers or sumthing..
rollindts
09-09-07, 08:30 AM
well i have found at least two others that have replaced the factory stereo with double din in dash lcds.. (which is what im doing - the alpine iva-w205)
below are images from two cars on cardomain..
http://memimage.cardomain.net/member_images/5/web/2537000-2537999/2537345_8_full.jpg
http://memimage.cardomain.net/member_images/9/web/2565000-2565999/2565276_30_full.jpg
http://memimage.cardomain.net/member_images/9/web/2565000-2565999/2565276_31_full.jpg
http://memimage.cardomain.net/member_images/9/web/2565000-2565999/2565276_32_full.jpg
http://memimage.cardomain.net/member_images/9/web/2565000-2565999/2565276_35_full.jpg
ill try and call after i get off work..
I realize the mounting kit will need to be custom made (as with the 00-05 devilles).. im just wondering what adapters ill need to retain which functions (i have a general idea because i was planning on purchasing an 05 but the 0 percent financing worked out and so instead its the 07)..
