View Full Version : Is there a fuse that just shuts off ignition
Nrets
09-05-07, 07:38 AM
I have a 1970 coupe deville. Is there a fuse that shuts off just the ignition, but leaves power to the coil?
Spock
09-16-07, 01:31 AM
What do you want to do, have an anti-theft feature? Or is your ignition switch not working and you car won't even crank?
If you want anti-theft, you could put an inline switch for the coil and run it to wherever in the car. There are even switches that you can get for your battery terminal, also is handy so the car won't drain the battery on accessories. Those are pretty cheap to get and easy to install. You of course have to pop the hood every time, so good for storage purposes but bad for the mall.
