View Full Version : 98 & 99 SLS & STS Tuning only
AJxtcman
09-03-07, 10:18 AM
I want to break this up to preserve my brain. LOL
smooththg6969---- 99 SLS
axe--------------- 99 STS EU
mrnuke7571------- 98 SLS
mike0580a---------99 SLS
awdblackteam----- 98 STS
CASTOR TROY----- 99 STS
tripledoil-----------99 STS
AJxtcman
09-03-07, 10:26 AM
Originally Posted by CASTOR TROY
if i get mine by this weekend ill take em to the track in lowellville pa its $2 a run ill do a bunch of runs with and w/o aj,s pcm see what i come up with!
weather permitting! not a dyno but it may have some positive results.
CASTOR TROY has #1
I have done a few for myself, but he has #1 and #2.
#2 did not start, :mad: But that was why I sent 2.
I only have my 99 VIN Y Powered Fiero to play with. I needed a VIN 9 to try a different program.
We will have some result on this in a week or so. True numbers from the track
AJxtcman
09-03-07, 12:39 PM
CASTOR TROY
I am at a loss. I thought it was because of K29 RPO. I am running a K29 in my Fiero. The PCM I sent that did not start. Does it have a white sticker on it? I would like to know the 4 letters on it. example: CHTS, CPYK, CABY.
AJxtcman
09-03-07, 01:44 PM
GOT MY PCM,S!!!
aj you have exceeded my expectations i can feel the added power... on the way to work 2day broke over 130 i let off at about 142mph she had more tho... AJ YOU THE MAN YOU THE F-IN MAN!
moved
ronbo
09-03-07, 03:51 PM
Would this thread include '98 Aurora?
I bought a ECU from ebay that's from a '99 Aurora; says it fits 96-99 Aurrora, 96 Deville, 97-99 Deville, 96-99 Seville, and 96-99 Eldo
Tag on unit:
SERV.NO. 16214848 CPYD
AJxtcman
09-03-07, 04:21 PM
Tag on unit:
I am taking a step back and just doing the 00+ and 98 and 99 Seville's.
The one 96 eldo ate too much of my time. I am going to personally install it this weekend.
You stated that you want to do many mods to your car. I think after you get it all done I should work on a program. You talked about injector changes, T-body. I think that after you are done I should run the #s for the different injectors.
AJxtcman
10-03-07, 09:31 PM
:lildevil::bump:
smooththg6969
10-05-07, 05:16 PM
so Aj what do I need to get you started programming my Pcm I pmed you but got no response.
AJxtcman
10-05-07, 07:31 PM
I need a PCM #16214848
I am running short on them. I had some, but killed two, sent two out (NO PAY & NO RETURN ON THE SECOND ONE). I have two currently, but they are spoken for. The last two I purchased ran $50 each.
This PCM fits 96 to 99 Northstar's and Old's Aurora :bouncy:
smooththg6969
10-05-07, 08:15 PM
ok Aj I just bought one out of a 99 Deville it should be here next week. do you want to pm me your address so I can get it shipped out as soon as it gets here? also is there any way you can get rid of the Pcm420 code I get every now and then ? I know why its there I have a high flow cat and magnaflow mufflers or am I gonna have to get the o2 sim thanks
STStyle
10-08-07, 12:33 PM
Please add me to the list I have a 1998 STS
vin 1G6KY5499WU903033
I'm guessing I need to get a PCM 1621484
Please PM with your contact info and cost
Thanks
Craig
AJxtcman
10-11-07, 09:01 PM
I am working on some new programs. The ones done are great. The next step are going to be a PCM that I would not suggest running for more than a few hours at a time. It will foul the plugs out, but it makes loads of power.
Crown Vic Owner
10-12-07, 05:07 AM
AJ can you PM me pricing on this and whats involved?
AJxtcman
10-12-07, 03:05 PM
I am working on the Po420
I will PM you later. I am going out after work so it maybe late
STStyle
10-12-07, 11:37 PM
Don't forget me !!!!
Well, looks like I need 2 now. 1 as a daily driver and 1 for the track.
Craig
coaster
10-13-07, 03:23 AM
aj please pm me about speed limiter I have a 98sls with s speed limit 112 mph what do you need Iwill provide it to you whatever it is please thank you. coaster
parts68
10-13-07, 09:45 AM
I have about 4 extra PCMs for the 96-9s
Also have the 93-5 Memcals and PCMs.
AJxtcman
10-13-07, 01:33 PM
hey Aj I went a bought a total of 3 pcms for 96-99 programming I have them in front of me. can you pm me your address so I can get them shipped to you. also what programming options do i have for my 99 seville sls http://i125.photobucket.com/albums/p70/smooththg69/Image035-1.jpg
They made it here
Crown Vic Owner
10-14-07, 05:29 PM
AJ, waitin for that PM, not sure if you didnt remember or what.
Just saying.
AJxtcman
10-20-07, 03:07 PM
It is all done. I am working on a P0420 removal for the second PCM:sneaky:
I have a 00 to 03 with all the emissions removed from it, so I know I can do it.
Crown Vic Owner
10-21-07, 01:12 AM
AJ, no PM back
told ya, 98 SLS, newish motor (5k)
AJxtcman
10-21-07, 03:59 PM
AJ, no PM back
I cleaned out my inbox. I saw your PM and left it. I then checked my out box to see if I had PM'd you.
As you know I did not. I need some information on that motor and trans.
I need some ID numbers.
Crown Vic Owner
10-22-07, 03:51 AM
what numbers and how can I get them?
AJxtcman
11-12-07, 10:31 PM
This was a fun run. I ran the speedo back to 0
VXTMhojkmhE
AJxtcman
11-12-07, 10:33 PM
I am going out for another run. I hope the boy can work the camera better:duck:
AJxtcman
11-12-07, 10:55 PM
ah that sucked. The boy is blind. He can't see the speedo. I have no idea how he can go with out his glasses. :banghead:
caseykiller56
11-12-07, 11:29 PM
I know how to use the camera AJ but the "speedo" doesn't give off any light to see and the steering wheel was in front of it.
The icon is me and i'm cool!
AJxtcman
11-12-07, 11:35 PM
Watch out or I will get my dogs after you:rofl:
http://i224.photobucket.com/albums/dd25/AJxtcman/Bambam%20Dino/2.jpg
:farting:
http://i224.photobucket.com/albums/dd25/AJxtcman/Bambam%20Dino/1.jpg
Go kill a deer
:horse:
STStyle
11-28-07, 11:18 AM
Hey AJ
Do you have any 98/99 STS PCM for purchase. if so can you pm me with details
AJxtcman
11-28-07, 07:48 PM
:bump:
AJxtcman
03-17-08, 08:41 AM
9388186 = 239.9hp
AJxtcman
09-10-08, 02:49 PM
GOT MY PCM,S!!!
foos
09-11-08, 11:15 PM
Count me in for a 99 STS ..
What do I have to do? And what are the list of things you can change on it? Obviously speed limiter but what about torque management, emissions ( I have a high flow cat which trips the 0420 a lot), shifting, better tune with intake/exhaust work, etc etc..
I would assume you have to also install the modules in the pcms for the other devices.. Like If you have onstar the software in the pcm needs to k now about it , or if you don't have it it needs to be disabled.. I removed my onstar for example and now I get a IPC code constantly because it lost serial communication with the onstar module I removed.. This of course can be removed from the PCM..but I don't know how :) The dealer can do it most likely.. Anyway I am interested so if anything is ready for a 99 i'll try it..
I can buy some used PCM and send it over to you so my car isn't out of operation for a time..
Ur7x
09-12-08, 12:07 AM
When you get your new PCM do a couple of drag strip runs for us... Back to back if possible... One with the Tuned PCM one with the stock one... Please post the results.
The data we have on the 2000-2004 PCMs is they don't make the cars faster... they actually slowed down Codewises car a 10th of a second in the quarter... We are all curious if the 98/99 tune is better.
AJxtcman
09-12-08, 12:40 AM
Yes you are an Idi
WTF if you leave on 4 cylinders what could YOU expect?
I have kids with more brains than you have!
Why aren't you all over Code for the DataLogs?
I sent him out a $400 datalogger. We will see if it is my program. :rant2::rant2:
WTF :mad:
If the Datalogs come back showing that my program is not the problem then WHAT!:bighead:
Hey maybe it is the tune.
Maybe his car has an issue that will show up on BOTH PCM's :eek:
Then WHAT?
TTCAMINO
09-12-08, 12:52 AM
have a 98 cadillac sts, it starts fine when cold after warms up i have to crank and crank to get it to start. Any ideas what could be causing this????
AJxtcman
09-12-08, 12:54 AM
fpr
Ur7x
09-12-08, 02:48 AM
Yes you are an Idi
WTF :mad:
Then WHAT?
Then we will have no idea why your tune makes cars slower...
Your tune leaves on 4 cylinders too... So what.
The TRUTH is his car ran better on the Stock PCM... Maybe his car does have an issue... And we can now add that CadillacSTS2003's car is ALSO slower on the tune... The truth is every time we actually test the cars in any sort of back to back scientific way the stock PCM does better then the tuned PCMs.
All I'm asking for is more data, more tests, more results... As I have posted over and over THAT is how you make these tunes better...
Repetitively calling me an idiot does nothing to improve your tune.
AJxtcman
09-12-08, 07:14 AM
CadillacSTS2003 has NOT run a TUNED PCM in his car!!!!!!!!!! :alchi:
When did he get it running with the tuned PCM?
Ur7x
09-12-08, 12:42 PM
Oh please, you sent him a tuned PCM and he IMMEDIATELY started to have driveability problems... The car would not run to red line any more... etc etc... You had to send him a new one... We have not heard how the second PCM works, or if he even got it...
CadillacSTS2003
09-12-08, 11:24 PM
Ok ok guys lemme clear this up
AJ sent a pcm with a bad tune a tune we were going to test and it didnt pan out, it shifted far to early even after the CPK relearn.
The 2nd pcm he sent me was a mutal misunderstanding, he though i sent him back the poor running pcm when i actually sent him another pcm from a salvage car which was never installed in my car.
Because of this he did not set it up with the security "open" so I could not run the new pcm.
I have never done anything more yet to date, we have both been very busy, he asked me to mail the PCM back I gave it and the address to my father to mail it to him with his business account to save on shipping and he neglected to mail it out.
I hope to put it in the mail tomorrow.
That said AJ has been very forward and very upfront about everything in this whole process.
He has been helpful and on a few occasions I have called him and asked his input on other problems to pick his brain which had absolutely nothing to do with tuning.
I trust the guy, if he was out to screw anyone he wouldn't of provided us with so much info on how to contact him, where he works etc etc etc....
