: Whir while turning
smoey847
08-25-07, 10:13 PM
Hi. I own a 2005 STS V8. Lately, I have heard a little whir or whine while going around some curves. Any ideas? Thanks!
dkozloski
08-25-07, 10:26 PM
I've had that and it was tire noise.
z06bigbird
08-25-07, 10:47 PM
Check blinker fluid.
Lifer
08-26-07, 12:36 PM
Yea, there may be a bear in there. An old bear. :thumbsup:
z06bigbird
08-26-07, 06:17 PM
Like ancient???
dkozloski
08-26-07, 06:39 PM
Like ancient???
Old enough to know better but still young enough to not give a damn.
smoey847
09-01-07, 12:21 AM
Took it to the dealer today. Turns out something's wrong with the power steerin. I Think they said the fluid is leaking. Took it to the dealer: for two other reasons: 1. when i receive a call on bluetooth, they can hear me, but i can't hear them. only on receiving calls though, if i call them, everthing is fine. 2. the brake pedal makes a squeak.
StealthSTS
09-07-07, 08:33 AM
Smoey847: If your "whir on turning" is at low speed... and your power streering is OK... I had same problem that sounded like the steering shaft was binding (only at low speed)... Dealer scratched his head a couple of days, then found a problem in rack & pinion (steering mechanism)... Dealer replaced rack &/or pinion (warranty of course) and problem was cleared...
That is the only problem (with Blk/Blk, '06 V8 STS4) since bought new in Nov '05... Great car... Only competition was BMW 650, but with no rear leg room, $15k additional and only 2WD for the Bimmer... the STS was my choice.
fscpuz
09-07-07, 01:10 PM
I have started to hear that too on my 2005 STS V6 let me know if you found out what it is thanks
fscpuz
09-07-07, 01:14 PM
I have started to hear that too on my 2005 STS let me know if you found out what causes it. Thanks
Blake
09-12-07, 06:43 PM
I have same problem now, but only after a fix to another problem...and who knows, maybe its only coincidence? I had a clear fluid leak from rear portion of car...they told me it was a pinion seal and that a lot of these were having the same issue- after a couple of trys they got the car to stop leaking but now makes that sound and is a lot worse when I am trungin while backing up (kinda fast). I got used to it and no more fluid on the garage floor!
BTW I didn't think a pinion seal would be a big deal, but the dealer told me the job was over $700 if I wasn't under warranty.
jvizzy22
09-13-07, 01:00 PM
yea i hear it on my 05 V8 AWD, let me know the prognosis
smoey847
09-13-07, 09:04 PM
Dealer finally got the part in. Taking it in tomorrow. Not really sure what the actual part is, but it's leaking fluid. That's all I really know. They had filled it with fluid last visit, haven't heard it since... Go figure...
