: NEED HELP, located the temperture coolant sensor!!
08-24-07, 04:44 PM
Ok guys and gals....The error code said the coolant sensor was bad....so I go to my local Advance and get one....now the problem is I cant find anything that looks like what I have.....it is the 1981 fleetwood brougham with the 368 motor..its the 4-6-8 motor if you need that...
08-24-07, 05:40 PM
According to my 81 FSM, the coolant temp sensor is located just to the left of the coolant temp switch, which is just to the left of the base of the distributor. Follow the wires from the distributor cap, and you will find it. It is rights above the outlet for the water pump.
08-24-07, 06:35 PM
I think I found it, but hell no way in hell to get it out....I did notice the wires were frayed a bit and taped them up some....I hope that this is the problem, I am tired of the the disco light show on my dash!!:thumbsup:
08-24-07, 06:37 PM
Heres a pic of the old ride...
