: Low oil pressure warning
08-15-07, 09:28 AM
1994 Eldorado, 110000 miles
Driving home yesterday, I stopped at a store close to the house. So far no problems. I cut the car off. When I left, I had driven 1/4 mile and the "low oil pressure" warning came on. I was at my driveway so I pulled in.
I cut the key off and started the monitor systems and everything checked ok. No warnings, car sounds fine, plenty of oil. Got a clue what is going on? This is the second time this has happened, in the same place.
Thanks for any help,
08-15-07, 01:25 PM
It's likely the oil pressure switch. Rather common issue with high mileage cars. These electrical switches do "wear" over time. A new oil pressure switch should fix you right up.
08-15-07, 02:26 PM
Be sure to get a factory OEM switch and not aftermarket. Aftermarket switches more often than not have the wrong calibration.
08-20-07, 09:40 PM
Thanks for the help. I order the oil pressure switch today.
Got any idea where it's located on the motor?
08-20-07, 09:44 PM
It's on the oil filter adapter.
