Adrian12
08-13-07, 05:27 AM
hi guys
I've a question.
some time ago i asked because my cadillac stared very hard, but it was a broken ECM, since i got a new one the car runs nearly perfect.
now i've a problem with my idle gas... the car idles too low.
i drew in the screw from the ISC-motor because before the idle gas was much to high.....
now i want to have the correct idle gas, like described in the service manual but i dont know where to connect a tachometer for watching the RPMs of the car. in the book there is only written, that i should connect to the distributor but i dont know where.
then according to the manual i should run the car with 1500RPM and touch the ISC-motor to let it retract, then i should disconnect the ISC and should bridge A and B on the ISC-connector
okay then the ISC-screw should not touch the throttle and then the TPS sensor should have 0.5 volts with about 350RPMs
but thats the problem, without a tachometer i dont know how to do this procedure, and maybe somebody can help me in describing how to install a tachometer.
thanks a lot in advance
adrian
I've a question.
adrian
