Cadillacs89SDV,96FWB
08-12-07, 01:28 PM
I just bought a 96 Fleetwood. It needed a distributor so I'm in the process of installing it. I forgot where the vaccume lines go from the distibutor. Anyone know where they go? If I look at it long enough I'm sure I'll see it.
jayoldschool
08-12-07, 05:36 PM
One slips into your intake with a blue elbow. The other is on the drivers side edge of the intake. It has two one way vacuum valves in it.
96Fleetwood
08-12-07, 11:04 PM
What brand Distributor did you go with?
96Fleetwood
08-13-07, 07:42 AM
AC Delco
Great! I know people have been having problems with some aftermarket optisparks. I thought about going with MSD, but so far mine hasn't been acting up.
Did you finish the install?
jayoldschool
08-13-07, 10:42 AM
I would recommend putting in a new vaccuum harness to ensure the longevity of the opti. They are cheap insurance.
96Fleetwood
08-13-07, 11:49 AM
Good advice, the vent harness is cheap and better to do now while you are at it.
08-13-07, 06:39 PM
I did get the opti in and did run a new vaccume harness to it. I'd recomend installing the vaccume lines onto the distributor before you install. I found out the hard way. I'm also doing the new plugs and wires. I've got the left side, 1,3,5,7 done. I started the #8 today and snapped the coolant temp. sender off so there's some more fun for me. The opti was a breeze. Now if I can just get through 2,4,6 plugs and wires I'm golden.
HotPursuit
08-17-07, 01:06 AM
You are probably done with this project already, but incase you were not aware it can make it a little eaiser to go through your wheel well to access some of the plugs.
08-17-07, 06:01 PM
Thank's for the tip, I've have read that before and have removed plugs that way. I'm not done yet, maybe tomorrow. I work on cars all day and find it difficult to get motivated to do anything with a wrench after work.
