Hello fellow Cadi lovers, I am new to the board and Im pretty upset that I didnt find this site earlier. My issue right now is with my trunk. I have a 1994 Cadillac Seville SLS. The trunk used to work fine and one morning I closed my trunk and waited for it to automatically close itself and it never did. Does anybody know how or how much to fix this? Any help would be appreciated...Thank you
brougham
04-15-04, 01:15 PM
You can take the part out that the motor is on and twist it down by hand. Use the search button at the top of the page and youll be able to find something on it here about how to fix it, that problem has come up several times.
:welcome:
That was quick!! Thank you soo much for that helpful info, I will try it right now.
I dont know what Im doing back there...I got a few helpful tips in there but I really dont know what to look for...can anybody help?
Chuck C
04-16-04, 02:21 AM
I just had that problem last month...the dealer installed a new switch (it's part of the truck motor)
Do you know how much it costs for the new part?
DaveSmed
04-17-04, 06:25 PM
Try working the switch back and forth a couple of times. sometimes it comes back to life. If not, try a junkyard, I got a complete motor assembly and bracket for $15
caddyshack24
04-17-04, 06:36 PM
i had this problem just a few weeks ago..
So has my neighboor across the street.. he took it to cadillac and had the motor replaced for around $300
I got away with pressing the latch on the trunk lid & the latch which grabs the trunk to pull it down. Releasing both, the motor came back up... took it down properly -- chances are you have a short.. try bumping around in that area
.. mines worked eveer since
good luck
Chuck C
04-18-04, 11:16 AM
$300 sounds steep. I've had my motor replaced a couple of times: $50 for the part, $20 or so for labor.
Thanx for the helpful tips you guys, I will get on right away.
dannyboy
04-26-04, 01:03 PM
what was the outcome on your trunk?
It didnt work, I guess Im going to have to go to the junk yard or to the dealers, thanx anyways guys!!!
