AJxtcman
08-06-07, 02:17 PM
I will start with this information on an 03 Cadillac DeVille
Maintenance Schedule
Normal Vehicle Use
The maintenance instructions contained in this Maintenance Schedule are based on the assumption that the vehicle will be used as designed:
• To carry passengers and cargo within the recommended limitations as indicated on the Tire Placard located on the edge of the driver door.
• On reasonable road surfaces within legal driving limits.
• On unleaded gasoline of the recommended type. For information on the proper type of fuel to use, refer to the Owner's Manual.
Maintenance Schedule Intervals
The services shown in this schedule up to (100,000 mi) should be performed after (100,000 mi) at the same intervals. The services shown in this schedule to be performed at (150,000 mi) should be performed after (150,000 mi) at the same intervals.
For explanations of the maintenance inspections and services included in this Maintenance Schedule. Refer to Explanation of Scheduled Services .
For additional maintenance inspections and services which are not included in this Maintenance Schedule. Refer to Periodic Maintenance Inspection
Engine Oil Scheduled Maintenance
Change engine oil and filter as indicated by the GM Oil Life System™ or every 12 months, whichever occurs first. Reset the system.
Your vehicle has a computer system that lets you know when to change the engine oil and filter. This is based on engine revolutions and engine temperature and not on mileage. Based on driving conditions, the mileage at which an oil change will be indicated can vary considerably. For the oil life system to work properly, you must reset the system every time the oil is changed.
When the system has calculated that oil life has been diminished, it will indicate that an oil change is necessary. A CHANGE ENGINE OIL message in the Driver Information Center (DIC) will come on. Change your oil as soon as possible within the next two times you stop for fuel. It is possible that, if you are driving under the best conditions, the oil life system may not indicate that an oil change is necessary for over a year. However, your engine oil and filter must be changed at least once a year and at this time the system must be reset. It is also important to check your oil regularly and keep it at the proper level.
(7,500 mi)
Rotate tires. Refer to Tire Rotation in Tires and Wheels.
An Emission Control Service +.
(15,000 mi)
• Inspect the air cleaner filter. Replace the filter if necessary. If the vehicle is driven in dusty/dirty conditions, inspect filter at every engine oil change. Refer to Air Cleaner Element Replacement in Engine Controls. An Emission Control Service [Dagger].
• Replace passenger compartment air filter. Refer to Passenger Compartment Air Filter Replacement in Heating, Ventilation and Air Conditioning.
• Rotate tires. Refer to Tire Rotation in Tires and Wheels. An Emission Control Service +.
(22,500 mi)
(30,000 mi)
• Inspect throttle body bore and valve plate for deposits, open the throttle valve and inspect all surfaces. Clean as required. Refer to Throttle Body Service in Engine Controls. An Emission Control Service [Dagger].
(37,500 mi)
(45,000 mi)
(50,000 mi)
• Change the automatic transaxle fluid and filter. Refer to Transmission Fluid Checking Procedure in Automatic Transaxle. If the vehicle is mainly driven under one or more of these conditions:
- In heavy city traffic where the outside temperature regularly reaches 32°C (90°F) or higher
- In hilly or mountainous terrain
- When doing frequent trailer towing
- Use such as limousine service
- Uses such as high performance operation
• If you do not use your vehicle under any of these conditions, the fluid and filter do not require change until the message CHANGE TRANS FLUID appears on the Drivers Information Center. Remember to reset the Transaxle Fluid Change Indicator when the fluid and filter have been changed. Refer to Automatic Transmission or Transaxle Fluid Change Indicator - Resetting .
(52,500 mi)
(60,000 mi)
(67,500 mi)
(75,000 mi)
(82,500 mi)
(90,000 mi)
(97,500 mi)
(100,000 mi)
• Replace spark plugs. Refer to Spark Plug Replacement in Engine Controls. An Emission Control Service [Dagger].
(150,000 mi)
• Drain, flush and refill the cooling system (or every 60 months since last service, whichever occurs first). Refer to Draining and Filling Cooling System in Engine Cooling.
• Inspect the hoses.
• Clean the radiator, condenser, pressure cap and neck. If there is a loss of coolant, refer to Loss of Coolant in Engine Cooling.
• Inspect engine accessory drive belt. Replace if needed. Refer to Drive Belt Replacement in Engine Mechani
For time and/or mileage intervals of scheduled maintenance items, refer to Maintenance Schedule .
The following text and illustration describe the details of the required scheduled maintenance services.
For information on the proper fluids and lubricants to use, refer to Fluid and Lubricant Recommendations .
Engine Oil and Oil Filter Change
Replace the engine oil and the engine oil filter.
For vehicles without an oil cooler, refer to Engine Oil and Oil Filter Replacement in Engine Mechanical.
Engine Oil Quality
Oils of the proper quality for the vehicle can be identified by looking for the STARBURST symbol. The STARBURST symbol indicates that the oil has been certified by the American Petroleum Institute (API), and is preferred for use in gasoline engines.
Engine Oil Viscosity
Notice: Using oils of any viscosity other than those recommended could result in engine damage. When choosing an oil, consider the range of temperatures the vehicle will be operated in before the next oil change. Then, select the recommended oil viscosity.
SAE 5W-30 is the only viscosity grade recommended for your vehicle.
Use only oils which have the API Starburst symbol and which are also identified as SAE 5W-30.
If the temperature range is 0°F (-18°C) or above SAE 10W-30 oil which has the API Starbust symbol is acceptable if SAE 5W 30 oils is not available. Areas where the temperature falls below -20°F (-29°C), it is recommended either an SAE 5W-30 synthetic oil or and SAE 0W-30 oil. Both will provide easier cold starting and better protection for the engine at extremely low temperatures. Do not use other viscosity grade oils, such as SAE 10W-40 or SAE 20W-50 under any conditions.
Chassis Lubrication
Notice: Do not lubricate the parking brake cables. Lubrication destroys the plastic coating on the cable.
Lubricate transaxle shift linkage. Lubricate the parking brake guides, underbody contact points and linkage.
Tire and Wheel Inspection and Rotation
Tires should be rotated every 7,500 miles.
Check the tires for abnormal wear or damage. If irregular or premature tire wear exists, refer to Tire Diagnosis - Irregular or Premature Wear in Tires and Wheels.
Ensure the spare tire is stored securely. Push, pull, and then try to rotate or turn the tire. If it moves, use the folding wrench to tighten the cable. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Rotate the tires to equalize the wear and obtain maximum tire life. Refer to Tire Rotation in Tires and Wheels.
When rotating tires, always use the correct rotation pattern shown here.
Do not include the compact spare tire in tire rotation.
After the tires have been rotated, adjusted the front and rear inflation pressures as shown on the Certification/Tire label. Ensure that all wheel nuts are properly tightened. Refer to Capacities - Approximate Fluid .
Accessory Drive Belt Inspection
Inspect the accessory drive belts for the following
Cracks
Fraying
Wear
Proper tension
Replace as needed. Belts can have many small cracks in individual ribs without affecting the performance.
Brake System Inspection
Inspect brake lines and hoses for proper hook-up binding, leaks, cracks or chafing. Refer to Brake Pipe and Hose Inspection in Hydraulic Brakes. Inspect disc brake pads for wear. Refer to Brake Pad Inspection in Disc Brakes. Inspect the rotors for poor surface condition. Inspect other brake system components, including the brake calipers and the parking brake. Check the parking brake adjustment. The brakes may need to be inspected more often if the customer driving habits or conditions result in frequent braking.
Automatic Transmission Service
Change the transmission fluid and the transaxle fluid filter according to the maintenance schedule intervals. Use the proper fluids. For the fluid and filter changing procedure refer to Fluid Level Indicator Replacement in Automatic Transmission/Transaxle.
Inspect the drive belt according to the maintenance schedule intervals.
Inspect the drive belt for the following:
Cracks
Fraying
Wear
Proper tension
Replace as needed. For drive belt replacement, refer to Drive Belt Installation in Engine Mechanical.
Cooling System Service
Drain, flush and refill the cooling system with new coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
Replace the spark plugs according to the maintenance schedule intervals.
For the time and/or mileage intervals of scheduled maintenance items, refer to Maintenance Schedule .
For information on the correct type of spark plug, refer to Maintenance Items .
Spark Plug Wire Inspection
Clean the spark plug wires and inspect for burns, cracks or other damage. Ensure that the fit between the spark plug wire boots at the spark plugs and at the coils is snug. Replace the spark plug wires as needed.
Air Cleaner Filter Replacement
Replace the air cleaner filter according to the maintenance schedule intervals. For time and/or mileage intervals of scheduled maintenance items, refer to Maintenance Schedule .
Normal Vehicle Use
(7,500 mi)
(15,000 mi)
(22,500 mi)
(30,000 mi)
(37,500 mi)
(45,000 mi)
(50,000 mi)
(52,500 mi)
(60,000 mi)
(67,500 mi)
(75,000 mi)
(82,500 mi)
(90,000 mi)
(97,500 mi)
(100,000 mi)
(150,000 mi)
Engine Oil Quality
Chassis Lubrication
Cracks
Fraying
Wear
Proper tension
Cracks
Fraying
Wear
Proper tension
