View Full Version : Goto Shop? Or D.i.y. ?
juiceE
04-14-04, 10:38 AM
HEY, ALL LAC FANS!
when i check the codes under "04",
I get a 23 which i think is "wheel speed sensor circuit continually mlfunctioning"
and i get 63, which i believe is "BPM valve power supply malfunction"
What is the best way to go about to fix these prblms?
...by the way, I do have heavy rims
THANX!:confused:
juiceE
04-21-04, 11:05 AM
nobody? nothin ?? :P
DaveSmed
04-21-04, 03:14 PM
DTC 23 RF Wheel Speed Sensor Circuit Continuity Malfunction
Any brake/suspension work recently? I notice you have rims. Check and see if the sensor is plugged in, or if there is any visible damage to the sensor or the wiring.
DTC 63 Valve Solenoid Relay Malfunction
Best bet is to check the ABS fuse. If its not blown, there is a lot of circut checking involved. Let me know if you feel like tackling it. However, make sure you look for ovbious faults, like pinched wires (maybe around where the RF wheel spd sensor runs?)
