View Full Version : transmission debris.... here we go again b1gwi11 08-03-07, 11:04 PM alrighty... soo... its been awhile since i've posted here.... hope u guys can help me as much as you did last time.
well my transmission was slippin or something, so i checked fluid level and it was fine... thought maybe i should drain the fluid, fill it back up... change some gaskets (it had a bit of a leak)
so i take the pan off.... and drain fluid... and in the bottom of the pan ... what do i find.... well idk exactly but it appears to be a spring.... a couple green plastic pieces... and a bent up piece of metal.
pics: http://i136.photobucket.com/albums/q189/b1gwi11/08-03-07_2235.jpg
http://i136.photobucket.com/albums/q189/b1gwi11/08-03-07_2237.jpg
first one's just the parts laid out on a tissue, second has a quarter for size comparison
oh yea almost forgot specs:
1987 cadillac brougham d'elegance 5.0L v8 RWD
83k miles (i think... it could be 183k... theres only 5 digits in the odometer)
so i guess my question would be.... should i just get a new transmission.... can i fix this one.... are they unimportant parts.... (probley not)
any help is appreciated Jonas McFeely 08-04-07, 03:42 PM The phrase "transmission debris" makes me cringe. :eek:
Sorry i cant be of any help, my transmission is shot to hell too. b1gwi11 08-04-07, 05:02 PM The phrase "transmission debris" makes me cringe. :eek:
yea i read ur posts... good luck with yours.
new update..... i took some part out of the actual transmission towards the rear of the car.... could anyone tell me what it is?
pics:
it was sitting upwards like this in the car (note the missing chunk of green)
http://i136.photobucket.com/albums/q189/b1gwi11/cadillac/08-04-07_1637.jpg
then theres another angle
http://i136.photobucket.com/albums/q189/b1gwi11/cadillac/08-04-07_1639.jpg
and from the bottom
http://i136.photobucket.com/albums/q189/b1gwi11/cadillac/08-04-07_1638.jpg jayoldschool 08-04-07, 05:11 PM I think that green plastic gear is the speedometer gear. I could be wrong, but I will google and see what I can find. Nothing that holds a load would be plastic. They are differnent colours for different rear gear ratios and tire heights. Don't stop worrying yet, just hope I'm right:thumbsup:
Jason. jayoldschool 08-04-07, 05:22 PM Ok, I can't find any specific pics of that piece. I think I am right, but here is what I would do. Go to a transmission shop, and ask one of the techs what it is. Tell them what it is out of (TH700R4). They should know right away. If it is a speedo gear, they likely have them, or can get them for you. b1gwi11 08-04-07, 05:36 PM Ok, I can't find any specific pics of that piece. I think I am right, but here is what I would do. Go to a transmission shop, and ask one of the techs what it is. Tell them what it is out of (TH700R4). They should know right away. If it is a speedo gear, they likely have them, or can get them for you.
alright, will do.... theres a transmission shop right up the street....
but are you sure its the 700r4? i thought the 1987 brougham had the thm200-4r?
also could this cause it not to shift and whatnot? i would imagine so..... jayoldschool 08-04-07, 05:41 PM I love a challenge.
Take a look at this PDF file, it has an exploded view of every part in the trans. Find the one that you took out (I think it is #171), then you can figure out what you need.
TH700R4 parts (http://www.racetransmissions.com/catalogs/TH700R4partsCat_MonsterTransDotCom.pdf)
Hope this helps,
Jason. z06bigbird 08-04-07, 05:42 PM I figured it out. It is called the trans part near the rear with green plastic. Like someone else said, it is the gear for the odometer. You might have lucked out, except for some slipping.
If it is slipping, you do not want to drive car on freeway for any length of time, as tranny will overheat from slippage. jayoldschool 08-04-07, 05:44 PM Crap, is it a 200? I thought the 307s got 700s. Hang on, I'll go look up the 200.
lol jayoldschool 08-04-07, 05:53 PM Got it. It's a green 10 tooth drive gear in your 200-R4. They have them in stock at this place:
http://www.transmissioncenter.net/speedometer_calibration_______va.htm#200 b1gwi11 08-04-07, 05:55 PM Crap, is it a 200? I thought the 307s got 700s. Hang on, I'll go look up the 200.
lol
yes im about 95% sure after looking at that PDF....
my pan is rectangular with one corner taken off
like so
_____
|______|
also: thanx for all the help guys b1gwi11 08-04-07, 05:59 PM Got it. It's a green 10 tooth drive gear in your 200-R4. They have them in stock at this place:
thanks a bunch
have you ever used that specific site before...? just want to make sure its reliable
or alternatively would there be a place locally that would stock that kind of part? jayoldschool 08-04-07, 06:12 PM I'd check with a local shop - they might have the part right on the shelf. Stop by the dealer, too - they will be able to at least give you the part number, then you can check it online from places like gmpartsdirect.com. Also, try Napa, etc. It looks like that website sells a lot on ebay, too, so you should be good to go with them if you can't get it local.
They have the one you need on ebay (not the one in the pic):
green 10 tooth drive gear (http://cgi.ebay.com/ebaymotors/55X-200-4R-Speedometer-Drive-Gear-10-Tooth_W0QQitemZ140004143002QQihZ004QQcategoryZ3372 7QQrdZ1QQssPageNameZWD1VQQcmdZViewItem)
Jason. jayoldschool 08-04-07, 06:19 PM One more thing: after replacing that part, make SURE you adjust the TV cable correctly. Hopefully, that is why the trans isn't shifting properly. Also, make sure you have the correct amount of fluid in there, too. The wrong amount will screw up the shifts, too. b1gwi11 08-04-07, 08:18 PM thank you jay.... you've been a huge help...
theres 1 napa parts store near me thats open sunday so i'll go look there 2morro, otherwise i'll figure some other way to get it. b1gwi11 08-05-07, 11:24 PM alrighty.... sooo.... went to the NAPA parts store, and they werent open....
so i went to pep boys (yea im not too fond of them but it was next door)
and one of the guys knew what he was talking about for once
he said yea it is a speed gear, and the spring is apparently from the valve body, so im not entirely sure that getting just that parts going to fix my problem....
gonna talk to a guy i know at a transmission shop when theyre open 2morro. b1gwi11 08-19-07, 02:22 PM alright been awhile
ordered the part online, installed it, put transmission fluid into it
only problem im having now is the TV cable adjustment
in my haynes book it says its either in the engine or by the accelerator pedal.
well im 95% sure mine is by the accelerator pedal, but i have no clue how to adjust it.... it looks like the automatic adjusting one pictured, but i dont c any adjust tab or anything.... and i also have no idea what the other one would look like
anybody have any guides or anything on how to do it? Looked at this post a little late - just fyi, I have used both www.transmissionpartsusa.com and www.bulkpart.com many times with good results.
Every TV cable adustment that I have seen is done where the cable attaches to the bracket by the carb or throttle body. There is a metal clip that you pull out in order to allow the cable to be adjusted - once you pull the clip the cable will sort of loosen. You then mash on the gas pedal (engine off!) all the way to the floor in order for the cable to self-adjust. It has a rachet mechanism where the cable attaches to the bracket that sets the adjustment. You can modify the shifting a bit by pulling the cable up an additional notch after doing the pedal adjustment. Kinda hard to explain on-line, look up some Google info on TV adjustment, you will see what I mean. | |
