Instructions for 2000 Seville
(yours should be similar)
REMOVAL
*Do not let the overhead console hang from the wire harness
1. Carefully pull down on the overhead console to release the four retainer clips
(Illustration shows using a screwdriver on the forward bottom left corner)
2. Disconnect the flat wire electrical connector
3. Disconnect the cell phone microphone connector (if equipped)
4. Remove the overhead console
Just wanted to post back and confirm that this is correct.
You'll want to grab the front two corners first. Carefully and firmly pull down. Once those are free do the same in the rear corners.
Thanks
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
