View Full Version : A/C Stopped working
jimutc
07-26-07, 09:37 PM
I have a 1995 STS.
Was driving it the other day, and the A/C just suddenly stopped working. It was after I turned the car off, in the middle of the day (about 95 degrees), and restarted it, since it hasn't worked.
The compressor is not engaging. When I push "auto," to turn on the A/C, the fan spools up to the max-cool speed, but the compressor doesn't engage. So I am thinking it is an electrical problem, but all the fuses work fine (tested them all including the relay).
I also check to see if there are any codes, which there aren't any (not bad for a '95 with 155k miles eh?).
After reading some other A/C posts on here, I still can't figure out where to start! What else could be the problem? Should I try to refill the refrigerant before I spend $2000 by taking it to the dealer?
Thanks for any help, Jim
clarkz71
07-27-07, 05:58 PM
First thing to do is get some A/C gauges and check the pressure's.
Harbor Freight has a set on sale for $39.
Post the results and we can guide you from there.
Ranger
07-30-07, 10:47 AM
Check the electrical connector on the compressor and the relays if the pressures are OK. That said, if the pressures were low, you should have gotten a LOW REFRIGERANT message and a DTC.
jimutc
07-31-07, 04:14 PM
I tested the pressure and it was OK. So I took it to the shop, and they said it was the "high-side" connector, and it wouldn't turn the compressor on. I am not sure exactly what they said, because I've never heard of it, but they want $200 to drain the system, replace the faulty part, and then recharge it. Worth it?
Ranger
07-31-07, 09:18 PM
I don't know much about pricing, but that does not sound too bad, especially if you want A/C.
jimutc
08-01-07, 11:06 AM
Also, is $600 a reasonable price to replace a water pump that had been leaking coolant?
I ask this because as I took it in for the A/C, I asked them to check to see if they could find the coolant leak, and they said it was the water pump.
clarkz71
08-01-07, 11:10 AM
No it's not. Shop around. Book time for that job is 2.2 hrs
The pump is under $100. Even at $100 an hr that's $300 tops.
jimutc
08-01-07, 11:17 AM
"Book time?" I am probably naive here, but what book?
clarkz71
08-01-07, 11:24 AM
Dealers (Cadillac, etc) have a warranty time guide, independent shops have a labor guide.
Chilton, Mitchell and several others. I have a Chilton guide. And
2.2 hrs is generous. Most good technicians can change a Northstar pump
in less then an hour. Labor guides are what repair shops use to quote a job.
Times can vary a half hour one way or the other, that's why they're called guides.
clarkz71
08-01-07, 11:34 AM
An AC-Delco water pump part # 251-660 is $89 at Advance auto.
Check around, you can probably find a cheaper price somewhere.
That gives you an idea how much they are trying to make on you.
Ranger
08-01-07, 01:56 PM
Not to mention that it is one of the easiest water pump in the world to change. Don't let them tell you otherwise.
