View Full Version : electric fan override?
AKPsiMC03
05-06-03, 01:24 PM
My car has been running hot recently cus ive been doing alot of stop and go driving. I wanna know is there a way i can wire in a switch to manually turn on the second fan when it gets warm? this fan will only turn on when the AC is on.
and at what temp does the other fan turn on? is it 220 like most other GM electric fans?
Katshot
05-06-03, 01:59 PM
At Idle, with A/C "OFF", I believe the Primary Fan is set to 225 deg. F and the Secondary Fan is set to 232 deg. F
Hope that helps.
AKPsiMC03
05-06-03, 11:18 PM
how can i make them come on lower? I dont like the idea of an aluminum engine getting that hot before the fan goes on... esspecially if im in hot traffic or pushing the car hard.
I overheatted one car once and boiled the coolant... and i DONT wanna do it again.
Katshot
05-07-03, 08:34 AM
You CAN "back-door" the relays but you REALLY don't need to. The engine is designed to run at those temps. The mod is easy and there's even fan control kits available in parts stores.
