View Full Version : '06 maggied dyno, new low record?
Slaigher
07-24-07, 06:33 PM
Just got dyno`d. They didn`t want to tune it because of previous problem with a Caddy computer almost crashing it...They did say that vettes with similar setups were getting 450 - 470 rwhp.
Baseline (with B&B x-pipe) 331rwhp/333rwt
+maggie,B&B headers, magnuson tune 390rwhp/379rwt
Maggie putting out 5 lbs. (should be good for +/_ 100hp?)
looks like a typical dyno sheet, I`ll try to post it when I get access to a scanner.
Has anyone had an '06 maggie dyno tune?
I may have to get a CAI, lord knows I could use the +5hp.
Thought I was through with the mod bug...
bcholka
07-24-07, 06:45 PM
Go with a 2.8 pulley and a tune and you'll see 430-440 at the wheels :thumbsup:
NormV
07-24-07, 06:55 PM
Remember too tha the LS2, though bigger displacement, is running higher compression than the LS6. So your boost will be slightly lower. You just need a good dyno tune and you'll be there.
Norm
StealthV
07-24-07, 07:07 PM
MP112, 112H or 122HH?
Slaigher
07-24-07, 07:43 PM
No idea, none of the paperwork I have says anything about which one I have...
thebigjimsho
07-24-07, 07:56 PM
Truck motors and Maggies don't mix...:stirpot:
DILLIGAF
07-24-07, 08:00 PM
Your numbers look ok to me.
StealthV
07-24-07, 08:18 PM
What size pulley?
Slaigher
07-24-07, 08:43 PM
What size pulley?
2.9 stamped on the front pulley
DILLIGAF
07-24-07, 09:54 PM
My first dyno was 389 rwhp with a good tune on a stingy dyno,no cai,no headers,3.0 pulley with only corsa exh.Like it or not your close to where you should be.
wildwhl
07-24-07, 11:09 PM
Magnuson is now including a 2.9 pulley, not a 2.8 pulley, on their CTS-V units. Not sure why.
Personally, I'd recommend a 2.6 pulley and an awesome tune. You can even *mail order* both of them on this forum. You'll be so happy you won't give a shiat what the dyno sheet says.
WW
Luna.
07-24-07, 11:12 PM
Fax the pages to Magnason and tell them that is unacceptable. They advertise rwhp gains much higher than that &, in my mind, it's "their" problem to fix. They will probably send a smaller pulley.
5lbs seems way too low and your increase in HP is rather pathetic for a supercharger. You probably want to be hanging around 7 lbs.
wildwhl
07-24-07, 11:23 PM
:yeah:
But remember, Luna leaves his last name out on this forum.
Everywhere else he's Mr. Tic, so watch out.
WW
StealthV
07-24-07, 11:34 PM
It seems like deja vu from two years ago with the early adopters. This time it for a LS2. Could be the tune, could be the pulley, could be the IC circuit, could be the dyno, could be _______.
That's why we call it MOD HELL. :lildevil:
