View Full Version : fog install ??
"DaT_CaDdY"
07-22-07, 04:04 PM
After you have pried off the stock lense. I noticed there is a metal plate separating the DRL's from the fog. Do I need to remove the metal plate or am I just being scarry because the bend is that severe??
xocomaox
07-22-07, 07:25 PM
If you remove that plate, it's going to look like shit when you are using your turn signal. It's supossed to bend.
RobertCTS
07-22-07, 08:08 PM
STS-V fogs are a better solution:)
SvB4EvA
07-23-07, 07:31 AM
Use a pair of tin snips to cut the plate. You can remove it to do this, just pull on it and it will come out. Try and cut it to the curve of the new lense. See pic below.
:mad:
LUVMY04V
07-23-07, 08:29 AM
STS-V fogs are a much more expensive solution that doesn't match quite as well:):thumbsup:
xocomaox
07-23-07, 08:53 AM
:thumbsup:
:mad:
nickc50310
07-23-07, 09:03 AM
STS-V is what sissys who dont have the cajones for WW fogs do!
BURNT!
HAHAHA Just playin fellas! :thumbsup::stirpot::highfive::thepan:
LUVMY04V
07-23-07, 09:35 AM
STS-V is what dumbies who dont have the brains or balls for WW fogs do!
BURNT!
HAHAHA Just playin fellas! :thumbsup::stirpot::highfive::thepan::eek::alchi:
mrplease
07-23-07, 06:45 PM
BURNT!
agreed! WW's
