View Full Version : what type of fuel? mrplease 07-20-07, 11:47 PM what type of fuel do you guys put in your car? and do you have to put the high octane gas? just curiuos.
i bought my car this may and since i've had it i always put in the highest grade fuel. and the lady i bought it from says she always did to.
i have no plans to ever put anything other than the highest octane fuel, i'm just wondering if you can put regular gas in, and if anyone here does... 2004CTS 07-21-07, 12:01 AM I put 87 octane in my 2004 3.6L and it runs great (see owner's manual). Higher octane was "recommended" for the 3.2L. The 3.6L engine can benefit from higher octane fuel and will provide "peak" performance when its used. propninja 07-21-07, 01:52 AM I use Premium in my 3.2 although I've used mid grade with no problem. RobertCTS 07-21-07, 07:08 AM 87 is recommended. High octance only adds anti-knock additives for higher compression engines. So you're wasting your $$:yup: urbanski 07-21-07, 07:30 AM i tend to use gas, seems to work ok louiefl99 07-21-07, 08:30 AM I believe the general consensus is to use a quality gas at the lowest octane that keeps your engine from knocking. Available everywhere, check out www.toptiergas.com for more insight. I've driven my 3.6L CTS for almost 50K miles and I've used only 87 octane (mostly from top tier sources) without any performance or engine problems.
Try running a few tanks of 87 and see if you notice any differences. Mid grade is cheaper then premium, you might try that as well. CADIMAC52 07-21-07, 08:46 AM i tend to use gas, seems to work ok Now theres a concept:highfive: mrplease 07-21-07, 09:45 AM thats cool, thanks for the input guys.
i don't drive my CTS to much. maybe 2-3 times a week, more for recreational stuff anyway. i mostly drive the wifes aviator. if i put a lot of miles on the CTS i might consider using the cheaper gas, but if i'm only putting 100 miles a week on it so i'm not to concerened about the gas prices. ILLMATIK 07-21-07, 10:12 AM I use 87 most of the time. When its really hot i tend to put in the premium stuff though. caddy1219 07-21-07, 01:11 PM I always use Premium in my 3.6L because when I used 87 in my car it felt like it was stuttering on the take off and it never does it with premium. 87 and it runs fine. my parents would kill me if they found out that i put in premium. if i did i would have to start paying for gas, which i most happily pass on Caddylenz 07-21-07, 03:06 PM Hi, new member, first time on. Interesting I was actually going to ask this question earlier as I really seem to notice a difference when I fuel up with 91 or higher. There is the occasional place up here where we can buy 93. Good for the CTS and almost good enough for the F-18. RobertCTS 07-21-07, 04:20 PM I always use Premium in my 3.6L because when I used 87 in my car it felt like it was stuttering on the take off and it never does it with premium.
That's not normal. Have you SR look at it. Anything over 87 octane on a 3.6VVT is wasting your money.:yup:
I encountered some high RPM miss. A set of Denso Iridium Spark plugs fixed it. Not an easy DYI! caddy1219 07-21-07, 04:53 PM I guess my car acts a little different because with 87 I miss and it stutters on take off, but when I am running 91 it runs like a champ thats why I have stuck with 91 I have tried to go back down to 87 a few times and it will go back to stuttering so I feel I have to stay with 91 tonytun 07-22-07, 12:57 AM o0 shit am i wasting my money then? :-( i use 93 on my car--- i have a 2.8 cts 2007 but i did notice dat when i was using 87 the gas wouldnt last long so i started using 93 and saw a difference and another thing remember guys i live in miami and is hot as hell here everyday. what do you guys think??? should i go back to 87? and if i do would dat affect my car bcuz i was using 93? RobertCTS 07-22-07, 06:50 AM o0 shit am i wasting my money then? :-( i use 93 on my car--- i have a 2.8 cts 2007 but i did notice dat when i was using 87 the gas wouldnt last long so i started using 93 and saw a difference and another thing remember guys i live in miami and is hot as hell here everyday. what do you guys think??? should i go back to 87? and if i do would dat affect my car bcuz i was using 93?
It's the placebo effect IMO. The CTS 2.8 & 3.6 were designed to run on 87 octane. Some gas station may get condensation in their gas tanks(water) and this can make your car run lousey! caddy1219 07-22-07, 02:30 PM I am in Phoenix so my the 87 does break down faster in the tank and has condensation, where as the 93 has a little more additives that stops condensation. cossie1msu 07-22-07, 03:38 PM The higher the compression ratio the more effect higher octane fuel will have. For example the new '08 direct injection cts. Also vehicles with turbos/superchargers will need higher octanes due to the greater amount of air passing into the engine. If not used it will place too much stress on the turbo and burn it out. I use premium(92-94) just because I can't sleep well thinking that I'm not getting what I paid for (hp) and all that crap that builds up on the valves over time. Just my thoughts tonytun 07-22-07, 04:22 PM It's the placebo effect IMO. The CTS 2.8 & 3.6 were designed to run on 87 octane. Some gas station may get condensation in their gas tanks(water) and this can make your car run lousey!
so......what should i use? or what should i do? lol caddy1219 07-22-07, 05:06 PM IMO I would say use Premium, that is my thoughts about it but it is up to you Why is higher octane more recommended for the 03 as opposed to newer models? RobertCTS 07-22-07, 06:23 PM so......what should i use? or what should i do? lol
Tony,
87 octane will work great for your '07. Any more is a waste of $$ RobertCTS 07-22-07, 06:25 PM Why is higher octane more recommended for the 03 as opposed to newer models?
The '03 3.2 had a higher compression ratio requiring higher octane gas. The 3.6 and 2.8 are fine with 87 octane.:) tonytun 07-22-07, 07:08 PM ok thank you Robert RobertCTS 07-22-07, 07:12 PM ok thank you Robert
ZOOM Zoom Tony!!! xocomaox 07-22-07, 07:23 PM 87 always. bigblockcadillac 07-22-07, 08:07 PM I use the highest octane they got, but I got an 03 w/ the 3.2. No choice!!!
What can I say, the bitch has expensive taste:alchi: I use the highest octane they got, but I got an 03 w/ the 3.2. No choice!!!
LOL...so I should never use 87 with my '03? I've only been putting the highest, but I guess the medium 91 is fine? hey guys...
i have the 03 CTS and from my intepretation of the manual it says u can use 87 Octane, but Preimum is obviously recommended, I have put on about 8000KMs on the car since ive had it, I live in Toronto and i have used 87 octane for the majority of my driving.. I have to say it works fine..
However on my last fillup i used 91 octane and the acceleration at lower speeds is certainly better and noticable,
also i noticed once when i started my car it vibrated a bit (it was near empty on 87 octane gas) and when i put premium i didnt notice it. It could just be a one time thing cuz i never noticed a slight vibration before, even when using87 octane fuel.
My take is that 87 octane is ok for the 03 CTS if u dont push ur CTS hard and are an average driver, but if u want better performance premium is definately the way to go...
any1 else here use 87 in thier 03 CTS? ive only driven 8000KMs so maybe thats why i didnt notice a difference yet, any1 else here have more experience with this? BlueMalibu 07-23-07, 11:15 AM I was using 89 Octane until recently. I was in a freeway traffic jam recently and had the radio off and could hear some slight knock when tipping into the throttle. This caused me to switch to premium and the knock has gone away. When the weather gets cooler I'll probably switch back. tonytun 07-23-07, 05:08 PM but isnt premium gas recomend it and better? i really dont care about the money i guess is just like a 4 dollar difference everysingle time i full it......sry robert but i being thinking and i dont know what to do now lol i mean i just want whatever is best for my car....... now if premium gas is not good for my car then i guess i'll switch to 87 what do u guys think??? mrplease 07-23-07, 06:34 PM tony, if the extra money doesn't concern you then put in the high octane! i have always used the high octane and it works fine for me. and your right, its not that much of a difference in cost... RobertCTS 07-23-07, 07:42 PM Yep Tony, use what you want. The higher octane gasoline has anti knock additives. since you don't have knock why would you want to use it? A placebo for Tony?? bigblockcadillac 07-23-07, 08:08 PM Yep Tony, use what you want. The higher octane gasoline has anti knock additives. since you don't have knock why would you want to use it? A placebo for Tony??
Yeah, just wait until you have a problem, never try to prevent problems:alchi: RobertCTS 07-24-07, 04:55 AM Yeah, just wait until you have a problem, never try to prevent problems:alchi:
What problems?? It's the fuel recommended by the GM Engineers who designed the 3.6VVT. kbevere 07-24-07, 09:49 AM :hmm:Iv been told by the dealer when i gotten the car to use 87 i dont need anything higher! RScar627 07-24-07, 10:10 AM I bought my '03 with approx 25,000 miles on it and have put over 30,000 miles on it since. I tried both when I first got the car but didn't notice any appreciable difference so I have stuck with regular. Also, the dealer I bought from told me regular was okay to use. I believe the manual says to use premium for best performance but I really don't push my CTS to the limits. Chief_AT 07-25-07, 07:56 AM The higher octanes don't have more energy - just a different formulation to prevent knock. This is done by raising the 'vapor point' of the fuel - the pressure/temperature point at which fuel will self-ignite, which is what knocking is. Higher octanes will not work in very low compression engines (like lawn mowers [7 to 1]), because the low compression doesn't heat that fuel sufficiently for the spark plug to create combustion. Higher compression engines, like our 3.6, do, so higher octane is only needed if knocking is noticed with a lower grade. does higher octane fuel burn cleaner than lower? RobertCTS 07-25-07, 04:07 PM does higher octane fuel burn cleaner than lower?
No it doesn't unfortunately:( Aurora5000 07-26-07, 09:42 AM The Bottom Line Most cars don't need premium, but a few do -- and not necessarily the ones you'd expect. And premium's not likely to "clean" your engine, either.
While many people claim that their car runs better on premium, this costly fuel is really only needed in a few circumstances. However, when it is needed, it must be used to spare your engine from costly damage. On the other hand, if you burn premium when your car doesn’t need it, the damage won’t be to your engine but only to your pocketbook.
It’s All In The Numbers
The AKI (anti-knock index -- also known as "octane rating") of the fuel is an average of two different methods of computing the fuel's ability to resist engine knock. Regular unleaded gas in the U.S. has an anti-knock index of 87, while mid-grade is usually 89, and premium typically is 91 - 93. The higher the number, the more anti-knock protection the fuel offers.
Engine knock occurs when the fuel in the cylinder ignites by itself before the spark plug ignites it. The technical name for this condition is "pre-ignition." It sounds like marbles rattling around in a can, and it generally gets worse the harder you press on the accelerator pedal.
Knocking can indeed damage an engine because what is in effect happening is the "explosion" of the fuel/air mixture is trying to push the piston downward in the cylinder before it's gotten to the top of its stroke and is free to move downward. The engine is actually working against itself to a degree, and there is a lot of mechanical stress placed on certain engine parts, such as the pistons. In extreme cases, knocking can burn holes in the pistons and create other forms of engine damage.
Oil companies sell higher AKI fuels (also known as premium) to address this problem. A fuel with a higher AKI actually burns more SLOWLY than fuel with a lower AKI. This is because the fuel is less volatile and requires more heat input before it begins to ignite.
(For this same reason, high AKI fuels will actually make your car HARDER to start on a very cold day. In extreme cold -- below 0 degrees F -- you want a more volatile fuel which ignites easily so you can get the engine going without extensive cranking. So if extreme cold is expected, buy 87 AKI gas unless your owner’s manual advises against it.)
Who Needs Premium?
Basically, all premium fuel does is resist knock. So the short answer to the above question of “Who Needs Premium?” is simply any vehicle whose engine knocks without it. Consider these guidelines as you decide whether you really need premium or are in the majority who do not:
1. If your vehicle makes the above-described knocking sound when you accelerate, try the next higher grade when you refuel, and then see if the knocking goes away. If it does, stick with that grade. If not, bump it up another grade the next time you get gas. Generally speaking, high mileage vehicles with a lot of carbon deposits in the engine are likely candidates for needing premium or mid-grade gas, since these deposits reduce the volume of the engine's combustion chamber and make knocking more likely. In addition, the carbon deposits themselves get hot and may act to ignite the fuel if lower AKI fuel is used. High mileage engines do not always have carbon deposits; those that have been driven mainly in town and done a lot of idling are most likely to be “carboned up.” My Ford F-150 has 210,000 miles on it and does not knock on 87 AKI regular unleaded, so that’s what I use.
2. If your owner's manual calls for higher AKI fuel, use what the Book says. Usually this will be specified by manufacturers of high compression, high performance engines. If lower AKI fuel were used in these engines, performance would suffer because the engine's computer system would have to retard the ignition timing (reducing horsepower and fuel economy) to keep the engine from knocking.
But I Want to Keep My Engine Clean!
The higher AKI of premium gasoline does not in itself make it any cleaner than regular gas. Oil companies, however, like to advertise that their premium fuels are ‘specially formulated” to clean fuel injectors, restore lost power, and, hey, maybe even improve your sex life. But the truth of the matter is that any “cleaners” that could be added to gasoline itself are probably not going to be present in sufficient quantities to do much good.
A better strategy to keep your fuel injectors clean is to buy your gas from reputable stations that have a relatively brisk business. In this way the gasoline is liable to be freer of water and other contaminants. It’s also not a bad idea to avoid buying gas from stations while their tanks are being filled by a big tanker truck. It’s possible that the filling process could stir up gunk that’s settled to the bottom of the station’s storage tanks and make it more likely that debris could wind up in your own tank. (Gas stations have filters that are supposed to prevent this, so this is a minor point for those who want to be extra careful; it’s not a really big deal.) | |
