atikovi
05-05-03, 07:29 PM
I bought a '94 FW and will need to flush and fill the cooling system. Any problems with switching to Dexcool coolant that became standard with '96 models?
| View Full Version : Change to Dexcool in '94 Fleetwood? atikovi 05-05-03, 07:29 PM I bought a '94 FW and will need to flush and fill the cooling system. Any problems with switching to Dexcool coolant that became standard with '96 models? AKPsiMC03 05-05-03, 07:34 PM wont do you any good... and if you do you need to get every last drop and residu of the green stuff out of the dex-cool ill break down and not work right. just use the green and put the addative in. Allante North * 05-05-03, 09:33 PM Ditto what he said. Katshot 05-05-03, 09:52 PM There would be little benefit to using the Dex-Cool if it was not the "factory fill". And merely flushing and getting "every drop out" doesn't matter either. The actual main benefit to using the Dex-Cool is found through the initial break-in period which is when the Dex-Cool coats the aluminum engine parts with an extra protective coating. It can only happen on a new engine and anytime thereafter, even the tiniest amount of "regular" green coolant contaminates the cooling system for good. Therefore you might as well just stick to a good quality standard coolant. | |
