I noticed that my Fleetwood Brougham's traction control system works wayyyyy different than other Cadillacs I have ever driven .So, when you push the gas pedal down w/o flooring and traction is on ,my gas pedal goes forward on its own and then back to where it is after traction is off .
So, is it all about RWD vs FWD thingy or my '96 has a all different traction system .
With both a '93 and '95, all mine do is push back against you to kill the throttle when traction kicks on, and then stop when it's done. Not sure what you mean by making it go in when it's on...unless something changed, or your car is just weird. Technically, increasing throttle application would be the opposite of what's wanted...
Actually, no, I know of many (regardless of FWD/RWD/AWD) that all work the same way. Most will kill the gas back a bit like the Caddy (cable linked systems actually pushing back, and newer electronic throttles just electronically retarding it), and also most unlike the Fleetwood's older system apply the brakes to the spinning wheels.
All in all, the Cadillac's system is okay, but archaic like the car, and tends to also be oversensitive. It's actually helped me out a few times in slick driving, but for the most part, a regular locking rear diff (i.e. -posi) axle might have been a better choice instead of or on top of it, like the Buick and Chevy's of the same underpinnings had (and with no traction system).
Definitely agreed on the oversensitive issue .When making comparions between my FWD and Seville , I have to say Seville's system works more efficiently but still FWB's is ok .
When flooring the FWB , I feel my gas pedal push against me unlike Seville .
Yep, even if just a little, it tries to kick in and kill the acceleration you're pressing for, to theoretically keep the car in control.
On this note, you also must remember, these big, heavy cars were made with floppy road manners, and setup with low friction road cruising tires for older folks...hence, for their driving, the traction control is perfect. Anyone else, and more typical or aggressive driving, it feels like overkill to some.
Occasionally when I want to drive aggressively, I turn to the girlfriend and say "could you turn it off babe?" She then proceeds to open the glove box and turn off the T/C... and I leave a cloud of smoke from both rear tires all through second gear... :thumbsup: ... these Dunlops really can take a beating!
But for days when she is not in the car, I have to reach over and fumble to find that dern switch
It is annoying at times, the way it blips the throttle and hampers any kind of aggressive driving.. but I am glad it is there because I am sure there will be a time I will make a mistake and the T/C could possibly hamper it getting ugly.
It's not within reach just like my Seville .I reckon they intentionally put the button lest some people mess up with it lol .
BTW, trunk release button is in the glove box whereas they could have put it somewhere around the console .Glad, remote transmitter works nicely :thumbsup:
Even with the goodyear tires in other words not a high performance tires , the car is really so powerful and I feel it when I push a bit the pedal :bouncy:
I turn the system off every time I drive. Get in the car, fire it up, reach over and flip off TC, reach down and manually release the parking brake, seatbelt, ac, radio, etc. Gives the engine a minute to move the oil around, warm up a moment, etc. I don't have to look to turn off TC anymore.
I have a non Fleetwood axle in mine now with a 3.08's and a posi (tight one at that) and LOVE it. I don't miss TC at all, but I do miss ABS... But I should be getting to work on my Fleetwood axle soon..... Posi 3.42's soon!!
The BIG advantage of the posi over open diff is you have both wheels pushing the car, not just the one with the least traction. It may not seem like much, but it has made a large difference in how my car drives. I love it. The open differential primarily puts the power into the OUTSIDE wheel, this is the one that is turning faster, so it is the one with the least traction. The posi is biasing both wheels together, and it is putting power into both wheels and the wheel moving the slowest will push the car harder than the wheel on the outside, so the car will accelerate faster than an open, all things being equal.
Yup, not cheap! I have a fairly low miles Eaton Posi out of my 96 Suburban that I am going to rebuild and toss my 3.42's and get it back in my car. I have brand new GM axles ready too.
Ok, the downside. You enjoy it so much and end up wearing out your tires quickly!
I talked to B_Body_LT1 today and he pulled his 3.73's out to put 3.08's back in (whole axle swap) and he hated the 3.73's because the cruise rpms at higher speeds were too high. Here I am pondering 3.90's if I have to replace my 3.42's due to high wear. Hmmm.....
My thoughts if I were to go to 3.73 you might as well step up to 3.90's.... 3.55's aren't available in the 8.5/8.6 10 bolt, neither are 3.64's anymore (they were a special only for Buick GSX 455's...)
I don't see 75 for any extended time, and I don't go over that much at all, only for very brief times. But I do see a LOT of time in the 30-55 range. So having more gear would (should) lead to a better driving experience.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
