View Full Version : Started to shimmy.
aburzen
07-11-07, 09:26 AM
Hey all,
Last week my Lade started to shimmy. It feels like it is coming from the drivers side more. It happens when I am driving down the road. Any ideas as to what this could be? I know if it does this when I hit the brakes it is probably time for new pads or rotors. It is still the same issue if it is while driving? I also noticed my alignment is out so could this cause this "shimmy". Thanks!
aburzen
07-11-07, 09:37 AM
Well, well, well what do you know- Google it! Thanks anyways. I figured I would come to the guys that knew but google had the answer as well. Thanks anyways!
hcvone
07-11-07, 09:40 AM
If you are getting any brake pulse then usually your rotors are warpped and need to be cut or replaced, but I would start with a good front end alignment and get your wheels road forced balanced, what a difference with road force balancing. :)
Guyz1996deville
07-12-07, 12:20 PM
If it is not not that jack up your truck and check the wheel bearing. You might have a bad one..
dkozloski
07-12-07, 01:53 PM
You may have hit the curb, knocked off a wheel weight and damaged the suspension.
