View Full Version : Sign of upcoming headgasket problem?
sherfield2002
07-07-07, 02:17 PM
I have an 01 Deville. Last night I could smell coolant near the drivers side of the car. I didnt see any visible leaks though. This morning I had a "Check Coolant Level" message. What could be the problem? Could this be a sign of bad things to come?
AJxtcman
07-07-07, 03:23 PM
Crossover gaskets or water pump cover. You may have a water pump leaking also
Ranger
07-07-07, 04:20 PM
Had the same problem on my '03. Turned out to be crossover leak. There was coolant on the trans right under the EGR. Fixed under warranty. If it where a HG you would not likely smell coolant.
