I went for a little run down the freeway last Sunday with my foot in it, about 82 degrees outside. When I got back, the oil temp was reading 266, and the little bar was about 3/4 of the way to the right end.
I'm driving a 04 with about 3500 (yes that's right) miles on it. The excessive oil temp alert came on briefly once a couple of weeks ago, but went away after I restarted the car.
The warranty is still in effect, and I don't to mess the car up. Is it time to go see the dealer??? What is the upper end for oil temp??
On the track, my '04 can reach upwards of 280 or so... But check that recall. There is a recalibration of the oil sensor that needs to be done on early model '04s. Sit in traffic on a hot day and that ding-ding-dong will go off before the recab.
I'm having the same problem. The other day I decided to turn the AC on because it was so hot sitting at traffic lights, and alert comes on immediately. Temp was about 290.
I guess it's time to introduce myself to the local dealership. I just get the funny feeling their going to be like, "what TSB?"
Nah, you should be fine. Most Dealers will search SI for keywords like "oil temp" when they have a problem to diagnose and the bulletin will pop right up.
I hear ya...I also dumped out a break-in oil and went back to 30w from 40w - I was hot on the 40w but not in the alarm 300's - wondering if I should dump and go to the 40w again?
Good point about coolant temps and oil temps at cruising temps. Stock C5
LS1(intake and exhaust~400+ HP) is 190's for both at highway cruise. Saw 260 oil temps today at mid-ohio road course(210 coolant with no fans). If you keep the rpms up you'll see higher temps in both.
For those running boost or higher compression I'd look to lower temp thermo and a good tune including early fans.
Be sure to have the re-calibration done.
I had mine done, needs done again.
There was a second TSB, I see 310 -330+ every time (3rd or 4th session) at the track.
I just ignore it (now) since water temp seldome reaches 230 pyrometer temp on oil pan reads 220.
Oil typically 10 to 20 over water temps from what I have seen and read.
What intails the re-calibration - meaning, can I do it? or is this a warranty thing that I could slide in the 427 and cross my fingers?
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
