juiceE
04-08-04, 05:00 PM
Ok...this is my 1st post on a forum I should've joined a lOoooooOng time ago.
I am true Lac fan from a long time ago, im 22yrs old, own a 94 fleetwood, and previously I had a 92 deville.
So ive had this fleetwood for almost a year now, (not even @ 49k still)
I put on 20" 150 spoke rims on it...with the tires, the whole wheel size equals the stock rim+tire hieght, the stock width was 230 or something, im not sure, and these tires are 245.... + the rims feel 2x as heavy, or more.
http://www.cadillacforums.com/forums/attachment.php?attachmentid=1922
Im having a few problems...
The ABS+Traction control both went out, around the same time...@ first, they lights would turn on after driving 4 a while, and wen it was really cold out, it would take longer 4 both lights to light up, and now, they are just on continuously.
braking is horrible, I suspect the drums are out (i seen the forum about putting disks on in the rear, which has ben on my mind 4 a while now, I just dont have the money to even think about that right now)...i got the front rotors machined + new ceramic pads, and i think i might be using them too much since of the drums.
also there seams to be skweaking coming from front springs, thats only my guess though
my "air pump" fuse keeps blowing
the ride can sumtimes feel excessivly "not tight"
and wen i turn the wheel, at times, there sounds like a crack/popping sound
wut kinda of tierod bushings/ balljoints/ control arm bushings adjustments/repairs should be made, if any?
i already want to get bigger disk/pads in front, but since i just got them done not too long ago, i guess im goint to wait till their days are up
I also want to lift my ride. I read in some post that some1 installed heavy duty cargo springs...i would like to know of sum other ways i could get about a 5" lift all the way around. (is there any way to get into the computer and change the value of where the leveling sensor keeps the ride height at?)
and one more question, I want to get a billet grille, an i seen a post where he said sum website has them 4 under $200.00, I am really interested, and i checked it out, but can not find the web site.
I really want to get started on the work on my car, I just don't wanna go to a shop, an have them not do wut I want done, or over charge me.
thanx every one who actaully sat threw this long post, and Thanx 4 any ones input/responce.!
