john19990
06-26-07, 10:06 PM
Since my eldo 97 compressor is not coming on (no DTC codes), I need to check the A/C relay. I noticed that the A/C relay and Fuel Pump relay are tied with some black tape wrapped around both of these. My concern is that if I cut the tape to pull out the A/C relay, I will not be able to wrap around th tape again (tape is wrapped around and has almost no space). Any idea how to pull and test the A/C relay please.
Thanks
John
john19990
06-27-07, 04:20 PM
Please share your experience if you have ever changed AC relay.
Thanks
John
If it were me I would cut tape and check relay.
whitesoldat
06-29-07, 03:53 AM
Ahh yes very simply you cut the tape and then after changing or checking the relay either way wrap it with electrical tape, about the space thing its simple cut a 12" strip wrap it, cut another one wrap, you get the idea. or you can cheat like i do sometimes if they're on the ends just pull the tape back pull the relay and place tape back over.
