View Full Version : northstar shuts down
cracken-d-whip
06-24-07, 11:41 PM
well, im a newbie to these northstars.. what's the deal with the 4.6 northstar when it shuts down (sometimes) but then will start right back up and run fine.. i have a 96' concours. thanks
urbanski
06-25-07, 06:13 AM
moved from 2006+ DTS
please post in the proper forum for your vehicle
AJxtcman
06-25-07, 06:44 AM
Look at your under hood fuse box. Pull the entire plastic cover off and look fro corrosion or blue washer fluid residue or all the fuses or relays.
tpis15
06-25-07, 09:11 AM
Does it do it more often when it's raining outside? It could be a crank triggger.
fpmesiIII
06-25-07, 09:29 AM
how many miles on it? the throttle body could be so carboned up it causes it to randomly stop. this happens while at stoplights.
cracken-d-whip
06-25-07, 12:11 PM
I will check those things, but it doesn't necessarily do it when its raining. It will just shut off and that's it... weird
cracken-d-whip
06-25-07, 12:12 PM
oh.. it has 112k miles
cracken-d-whip
06-25-07, 12:17 PM
one more thing.. i don't usually mess with forums like this, so.. how do you find out when someone has replied to your posts? I had to search for this thread so i could find out if someone replied.. good grief.. I'm tired..
Ranger
06-25-07, 05:04 PM
Symptoms are suspiciously like a CKP sensor.
Have you pulled the codes?
AJxtcman
06-25-07, 08:48 PM
very rare if it is. I have seen more issues withe under hood electrical center on this vinatge.
I will be adding pictures to http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/110149-crank-sensor-pcm-history.html
Ranger
06-25-07, 08:53 PM
I have to admit that the '96 is not known for bad CKP 's.
cracken-d-whip
06-26-07, 12:15 AM
i have been looking at other models.. i have read a bunch of ad descriptions on ebay and have seen 2 or 3 different people describing this problem. "shuts off and then starts right back up..." type in this item number on ebay and read the ad.. 160131333447
