Hey all. I've got a question, mabye ya'll can help. My 84 DeVilles AC just quit working on me. When I hit the Auto or High button, you hear the compressor click on, the light comes on above your choice, but nothing comes out. I can feel a tiny bit of a fart of cold air from the vents, then its over. My friend thinks it might be a relay, but I dont know what that is. Or where it is.
Maybe your fan motor went out, so there's no 'wind' to deliver the cold air to you. I had that problem, and replaced the motor for 10 bucks at autozone. Two screws and ten minutes later I was chilly again!
It is as easy as changing a windshield wiper. First off, the fan motor is the round thing that looks like Abe Lincoln's top hat sitting right inside the hood in the corner next to the passenger side of the dash. There should be two screws plus a ground wire. Just undo those. Also unplug the wire that powers it; it's right on top. And unplug the small rubber hose. Then the whole unit pulls right out. There will be a turbine in there, so put it on your new one. Then work backards.
However before you go and replace the motor, you might want to make sure it's not something electronic that cutting power from a motor that would otherwise be fully functional.
Either the blower or the control module. The module is on the passenger side at the back of the engine compartment on the firewall where the HVAC stuff is.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
