sirving04
04-07-04, 08:49 PM
All of a sudden my right rear wheel is squaking could it be brake dusk or the rear pads or sensor gone bad please help guys ima go get it fix tomorrow or can i do it myself............any info will help thanks rodney....................
invincible569
04-07-04, 10:21 PM
Usually a brake pad will squeel/screech once it has met its end of life. There is usually a metal indicator when the pad is about 1/4 or less left that touches the rotor to produce the sound you are indicating. Inspect the brake pads yourself by removing your rims or have a specialist look at it.
sirving04
04-08-04, 06:13 AM
Thanks man ima change the brakes today..........thank you
invincible569
04-08-04, 10:07 AM
If your steering wheel shakes when you change the pads, then you may also need to turn (resurface) the rotors. You can do this yourself for like $5 a rotor at an autoparts store.
