goryr88
04-07-04, 11:47 AM
alright heres the scoop. I've been reading here for a while and trying to pick things up. I'm thinking that installing aftermarket head unit, amps, and speakers is quite a chore. first off, do i have to retain the factory radio in the mix somewhere? second, where do i find a mounting kit for a DIN receiver? is it the same as a deville? ALso, are the speakers a different impedance that will only work with bose systems? i curently have a premier deh-p850mp deck, rockford HX2 sub, and an old school rockford chrome power 1000 that i would like to install, but its looking like i will need another amp and new speakers since i'm thinking they are not going to work with an aftermarket amp. also what are the dimensions of the speakers in the bose system? i think they are 8" in the front and rear doors, 12" sub in rear deck, not sure about rear deck speakers or dash speakers and center channel. I have done many installs, but this is my first sts and i'm not sure if ishould tackle this thing, or pay a professional installer to do this. The bose system is nice, but not near what i'm looking for. Any help from you pros is greatly appreciated. thanks. Also, if anyone could recommend a good installer in iowa or closeby that would be appreciated too. thank you.:banghead:
JJhomer83
04-07-04, 11:53 AM
Go for it yourself you'll never learn unless you try take your time be careful and do you research. Save the money.
The Din adaptor find one for a cad around your year and try it out.
goryr88
04-07-04, 12:09 PM
any other information? i think i read a post here that took me to a site that had mounting kits but it only had a 97 sts and a 98 deville. not usre if those will work. what about the other things plus wiring harnesses? thanks
I installed an aftermarket CD changer and satellite radio in my '98 STS then again in my '03 STS. I installed a small Alpine system head in the small compartement at the bottom of the center console. The CD changer and Satellite receiver' are installed in the trunk. Although it uses an FM modulator the audio quality is adequate. A bonus is the CD changer is also an mp3 player. I can't recall the model number but I've been very satisfied with it. I also installed one in my '92 Allante and installed the control head in the center ashtray space.
This approach leaves the factory audio system intact which I believe will help your resale value if you ever decide to sell the car.
goryr88
04-07-04, 10:33 PM
thanks for the input. the only problem i have is i dont want to spend any money for more equipment other than speakers. i want more bass. i have it but i'm leary on how to install everything. i plan on keeping all the bose stuff and put it back in i f i resell it. know where i can get a mounting kit?
goryr88
04-08-04, 01:13 AM
ordered a mounting kit. i think it will work. it looks identical to the one in a 99 deville so i ordered it. ideas on how to relocate the factory bose radio? i believe it has to be kept in the mix somehow. suggestions? thanks guys. I appreciate all the help.
goryr88
04-18-04, 11:29 AM
what about a spot for the factory bose radio. Do i have to keep this in the ciruit? Is there some other type of bypass thing i can buy so i dont have to run wires to the radio in the trunk? please help!:banghead:
leprcon
04-18-04, 11:45 PM
i am also hving the same problem looking for a interface/relocation for thr factory radio anybody at all? part #s :worship:
DaveSmed
04-19-04, 12:06 AM
Ill look up the manufacturer, but someone makes a harness that allows you to relocate the factory HU to the trunk. Then you can rewire the car, replacing the speakers, or keep the existing wires, and have a 4-ch amp in the trunk to drive the aftermarket speakers.
JJhomer83
04-19-04, 08:52 AM
I picked one up at bestbuy for a friends car when i did his install they are very expensive for what they are though
goryr88
04-19-04, 11:07 PM
here is the link to the oem adapter i just purchased from crutchfield
http://www.crutchfield.com/S-DaSBOAjZ373/cgi-bin/ProdView.asp?s=0&c=11&g=751&I=120702006T&o=p&a=0&cc=01&avf=N
it says for 2003 and up but it looks identical to the one i need for my 98 sts. anyone know if this works or not? thanks
