View Full Version : rough idle in park??? 94 fleetwood.
cadydaddy
06-16-07, 01:51 AM
Its not bad, but my car sometimes has a slighty rough idle, ONLY IN PARK.
in drive, at a light, it has zero shake.
Anyone have any ideas?
how hard are plugs and wires to do on the LT1?
lochenjons
06-16-07, 02:50 PM
check for a vaccum leak. take off the air filter with the car running in park and spray carb cleaner all around the base of the intake manifold. if that doesnt help, let me know cause i have a few other tricks in mind. my truck had the same problem and this cleared it right up.
96Fleetwood
06-16-07, 04:59 PM
Plugs and wires are easy to do on the driver's side... a pain on the passenger side.
It could be many things, from a air leak to optispark... hard to diagnose, is it throwing any codes?
caddycruiser
06-16-07, 05:53 PM
Uh, NO, NOT a good (or even valid) idea with a fuel injected car--an LT1 is a lot different than any old 80's carb wonder.
That said, the LT1 seems very sensitive to any ignition irregularities and there can be a lot of random misses from one time to another, from any variety of sources.
Yours, though, is ODD, that you only seem to notice it sitting in park. Since it seems fine when in gear, it could be almost anything. Actually, just off the top of my head and something I'm reading right now, maybe try a good cleaning of the throttle body and IAC (Idle Air Control), which might be gummy or something only when the sitting in idle mode:
http://impalassforum.com/noncgi/ultimatebb.php?ubb=get_topic;f=33;t=012568#000000
http://impalassforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=33;t=012195#000003
and others (just need to search, as I used "rough idle"):
http://impalassforum.com/cgi-bin/ultimatebb.cgi?ubb=search;search_forum=33
jayoldschool
06-16-07, 06:26 PM
IAC cleaning is good advice. EGR replacement might be an idea, as well.
cadydaddy
06-16-07, 11:01 PM
Thanks for the tips guys, 96fleet...no codes, well the cel is not on at least, I will go into diagnostics to check that.
I will do some reading on the links, thanks.
What ever it is does not seem to effect mileage as I got 29 the other day, does that help at all?
Does the over the counter injector type stuff work? what about sea foam?
