View Full Version : 2000 Cadillac stalling
steelerfan
05-01-03, 03:08 PM
6 days with 2K eldorado and it has stalled twice on me. First time sitting at light, ( risk of being rearended.). The second time I was cruising down the road at ~40MPH and then shutoff. Anyone else have experience with a problem like this. Now I know why previous owner traded car in. I don't want to lose faith in this car so quick, I really like the look and confort. Car has 50K and just went over warranty.
gspencer914
05-01-03, 07:48 PM
You need to check the On Board Diagnostics, or OBD2 and see if its throwing you a code. If so let me know or email me and I can tell you how to pull it up and look up your code. If there is no code then i will have to go from there. Let me know if you need any help.
George
steelerfan
05-02-03, 05:41 PM
Pulled the numbers and got PCM codes P0386 Crankshaft Position Sensor B Circuit Range/Performance , p562 system voltage low, p1106 Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage and p1599 Engine Stall or Near Stall Detected. Dealer (Reliable Pontiac/Cadillac worked with me and determined it was the crank sensor and they are covering the fix for me. Actually having a history of working with this dealer is one reason I bought the car. They have always been very responsive and good to me before. Now I hope this is the end of issues and I can start to enjoy the car.
gspencer914
05-02-03, 06:19 PM
Great thats what it sounded like. The crank sensor is a common problem with the northstar. Glad you got it fixed.
Devil_concours
05-03-03, 01:18 AM
mine has started stalling week after dealer put in a new engine. I got it back they told me that it was the EGR valve getting stuck, it was good for a while but it started stalling again.
They told me that if it's a bad crankshaft sensor, it won't be covered under warranty. It sucks that every time i get the car back from this place my car will have another problem within 2 week.
Chuck C
05-03-03, 01:12 PM
devil_c.. i also had the egr valve prob...scary when the car would suddenly speed up and then stall
