: Dealer refusing to fix "service tire pressure sensor" message under warranty
sj22
06-05-07, 09:07 PM
Greetings,
I have an 05 Cadillac, 20,000 miles purchased as used from the first owner. I took it to the dealer and did an oil change and asked him to check the message "service tire pressure sensor". He is refusing to do it under warranty claiming that the 22" tires were put on after purchasing the vehicle. Should I fight or pay up to fix it ?
I have a good tire shop that I have been going for 20 years and I am going to have him replace two tires. When I change the two rear tires, is there a way to tell which sensor is bad? Also, where can I find information on removing and reinstalling the sensors when I change tires.
And some info on resetting the sensors will be helpful.
Appreciate the help - Thanks!
SJ22
Rolex
06-05-07, 11:34 PM
Any service dept for any make of vehicle will deny warranty coverage where aftermarket parts may effect the wear and tear of the vehicle. It's not even necessary that they prove the aftermarket add-ons caused the damage; their position is it CAN result in excess wear and tear. Of course if it CAN = coverage denied.
That's unfortunate for you, but a risk you take with modifications to ANY vehicle. Good luck my friend. :)
EXT_Vegas
06-05-07, 11:36 PM
You are asking them to warranty some else's product. They did not build, mount, install or receive payment for doing such. Yet you ask them to warranty it. You'll have to pay them or somebody else. Sorry...
Playdrv4me
06-05-07, 11:39 PM
Your SOL... the TP Sensors are part of the factory wheels... if you put aftermarkets on there, theres no way to prove your upgrade isnt causing the problem. This time im gonna have to side with the dealer.
GM-4-LIFE
06-06-07, 12:08 AM
Try a different Cadillac dealer and see what they say. Often times I have found that when one dealer is being difficult to deal with, there is always another dealer that will do it.
SG
FRISBEE
06-06-07, 12:12 AM
who knows if the sensors are still in the wheels, some aftermarket wheels make it impossible to remount them in the stem hole. We installed some 22's on my Cousin's Trailblazer SS and had the dealer turn off the tire sensor message for the fact that the sensors would not fit with the wheels my Cousin bought
vietfob714
06-06-07, 02:38 AM
Theres special adapters that i had to put on my TPS cost about $80 It has the sensor go flat instead of verticle so if i do get a flat, i wont break the sensor.
ewill3rd
06-06-07, 06:39 AM
Also if the sensors are mounted at an improper angle the reed switches inside the sensors that make contact to let them transmit will not function.
Some aftermarket wheels don't take the mounting angle into account and they won't work properly.
There is also a possibility that the tire installer cracked the sensors if they didn't install them properly.
It doesn't look like you are denying that you have aftermarket 22's installed.
If it were me, I'd offer you this: If I took the rims apart and found that whoever installed the tires broke the sensors or they were mounted incorrectly causing them to not function you would have to pay. If they had failed in a manner that would be consistent with a factory component failure I would make sure it was covered under warranty.
You may have to tell your dealer that you are willing to pony up if the problem was not a part failure.
You could always take it back to the tire installer and tell them their could be an issue with their work.
After all, if they mounted the tires wrong, they are the ones to blame... not GM, and frankly they should stand behind their own work.
hcvone
06-06-07, 07:05 AM
Bill well said, and if you go to your dealership and tell them you are willing to pay if it's broken from poor installation or the mounting of the tire caused the problem most dealerships will work with you. Some of the tire pressure resets do not work thru the DIC you will need a reset tool, some tires shops have them and you will need this if you rotate or change a sensor.
urbanski
06-06-07, 07:16 AM
just buy a new one and have discount tire fix it, $100 tops
cadillac_tech
06-06-07, 11:26 AM
sj22,
Just to give you more confidence, ewill3rd and hcvone are right. If you have OEM sensors in those wheels and they're not physically damaged, the dealer should warranty the failed part. It's not hard for them to figure out which sensor/s are bad and inspect it. If something is damaged, it's your dime.
Let's say you pay the dealer to replace the sensors. Would they claim there is no warranty on it because of the wheel?
DLE
06-06-07, 12:14 PM
I bought my 24" wheels that came with no TPS. My message is on my DIC everytime I start the truck up, but I just hit the button and it goes away.
Maybe those TPS aren't oem that is on the 22's?
sj22
06-06-07, 07:43 PM
Thanks to All...
I purchased one sensor from their parts department, I want my tire shop to put it in. Where can I find the instructions for mounting the sensors correctly and resetting them
Regards
SJ22
ewill3rd
06-06-07, 09:46 PM
Whoever replaces them should not have a problem mounting it properly.
Most wheels only allow one position. If it is not the correct angle it may have a problem but it depends on the type of wheel.
As for programming, I didn't read back but I am assuming this is a pre-'07 vehicle.
Turn the key off and wait for about 30 seconds (or more).
Set the parking brake, turn the key to run.
Within 5 seconds or so, turn the park lights on then off then on then off... 4 times total, the horn will chirp (twice I think).
Now go to the left front tire and let air out for about 10 seconds and then wait about 10 more. The horn should honk. Repeat this process on the right front, then the right rear, then the left rear.
The horn should honk twice after the left rear.
Turn the key off and release the parking brake.
Adjust the tire pressures to whatever spec you prefer.
Enjoy!
hcvone
06-07-07, 07:31 AM
Don't be surprised is the inflation/deflation method does not work, your tire shop may have a reset tool, I purchased one myself because one out of my two 07's did not work, and putting air in and taking it out was a pain. Any good tire shop should know how to install the sensors. :)
sj22
06-07-07, 07:34 AM
ewill3rd,
Thanks, mine is an 05 Escalade
I got it through this part...
Does it mean to adjust the PSI setting in the console or Adjust it on the tire by releasing or putting more air into it to make it 36psi?
Also, is there a way to find out which of the four sensors may have failed. I have a spare with me
Regards
SJ22
sj22
06-07-07, 07:37 AM
Thanks hcvone,
pls read my post, which was posted few seconds earlier than your reply. Is the ideal tire pressure for an 05 escalade 36 psi
My tires are P305 45 R22
Regards
SJ22
ewill3rd
06-07-07, 08:29 AM
The pressure increase/decrease method usually works pretty well on Escalades, but as stated... not always.
To find out which one is bad, just try to program them.
If one of them refuses to program but the other 3 work, the inactive one is probably the bad one. Don't worry that they won't learn in their proper positions until after it is fixed.
When you are done, adjust to whatever psi you prefer for driving.
To program you have to increase or decrease the pressure 1.6 psi(I think), this usually just takes the 8-10 seconds. Some guys let air out until the horn honks, that works too but you have to add more air afterwards... no big deal either way.
The programming tool works great but they run about $400!
Not really a worthwhile purchase unless you own an auto shop.
hcvone
06-07-07, 09:19 AM
I got a new Bartec 300 for $297.00 shipped, it does all makes foreign and US cars and can be programmed via the internet for the future, but with all my cars and SUV's having pressure sensors it makes my life easier. :)
hcvone
06-07-07, 09:19 AM
Thanks hcvone,
Regards
SJ22
35-36 lbs. :)
ewill3rd
06-07-07, 12:14 PM
This feature is about to be standard equipment on all new cars so if you are going to have a lot of them it could be worth the money. I have only seen the GM one and I know it available for retail purchase but expensive.
It sure works quickly and it is pretty much required on all the cars we work on now.
hcvone
06-07-07, 02:20 PM
I was goping to get the GM Kent Moore unit, but the Bartec offered more in terms of the different cars it could do. :)
sj22
07-15-07, 12:28 PM
Thanks Everyone...
