79lac
06-02-07, 10:56 PM
so i got my new quadrajet tuned to perfection. the only problem is the driverside tailpipe has a slight miss. (true duals all the way back). Any ideas to what this could be?
| View Full Version : new carb but still hesitates any ideas? 79lac 06-02-07, 10:56 PM so i got my new quadrajet tuned to perfection. the only problem is the driverside tailpipe has a slight miss. (true duals all the way back). Any ideas to what this could be? kiowamec 06-04-07, 10:49 PM Check to see if you have any ignition timing or quality issues and idle mixture and rpm is set correctly. kiowamec 06-04-07, 11:44 PM Forgot to mention EGR failure will cause air/fuel mixture issues also. 79lac 06-05-07, 02:19 PM when the car idels it will shake every now and again. once you drive it just as you tip into the gas peddle, it stutters a bit. i think the egr is good, i took it off and looked at it. i sprayed the whole motor down with brake klean as well... nothing happend as far as the engine racing. kiowamec 06-05-07, 03:07 PM Sounds like an ignition issue and most likely is compunded by some of the above. i.e. weak ignition, partially clogged egr and slightly off idle mix. Wheelman322 06-20-07, 11:48 PM I have the same issue with my 78. Rebuilt carb/motor/etc.... I'm inspecting now. Let you know what I come up with. 79lac 06-24-07, 09:09 PM im thinking egr myself... but it only seems to miss from one tail pipe... i just regapped all plugs, replaced cap, rotor and plugs again just incase. when i had the EGR off i put a new gasket on cause the old one was shot. the diaphram seemed to work perfect. maybe i will try a new one any way... i also sprayed the whole engine with brake cleaner and found no surges or anything. i am stummped at this point! ttt kiowamec 06-24-07, 10:38 PM What procedure was used to set the idle mixture screws? | |
