: Clutch resevoir leaking
gergreg
06-01-07, 01:00 AM
If some of you remember, I was happy with the shifter after having told the dealer to fill up the clutch res. with brake fluid. It lost it's smoothness and the clutch pedal has been studdering so I checked the reservoir and its back under minimum. I've never found fluid under my car after it's been parked. Any ideas?
50 4Ever
06-01-07, 01:27 AM
As the material on the clutch wears off the fluid level will go down to compensate. The reservoir is quite small so you notice it more.
gergreg
06-01-07, 01:30 AM
I had it filled last week.
50 4Ever
06-01-07, 01:35 AM
It should not go down that fast. Maybe the bleed valve isn't quite tight enough. Got me on that one.
