View Full Version : Dunno if anyone is as anal about tire pres. as I am (good deal)
nikon
05-31-07, 11:20 PM
http://amazon.com/s/ref=nb_ss_gw/102-8524776-5246567?url=search-alias%3Daps&field-keywords=Accutire+MS-5510B+Racing+Tire+Gauge&Go.x=0&Go.y=0&Go=Go
Everywhere else I checked they're ~50+shipping, this was ~40shipped....pretty cool gauge mainly because it measures in .1lb incriments :yup:
Rey
06-01-07, 08:21 AM
While digital tire gauges are nice, a good quality old-fashioned pencil gauge can work just as well and requires much less space. I use a NAPA gauge, which cost all of $8, which was a lot for a pencil gauge. I have matched it against known calibrated digital guages; and it has always been accurate for over ten years now.
StealthV
06-01-07, 08:36 AM
This is the one I bought many years ago and seems to be pretty good as it matches up at all four corners with the in-dash pressure display.
http://www.amazon.com/Accutire-MS-4021B-Standard-Digital-Gauge/dp/B00080QHMM/ref=cm_lmf_tit_2_rsrssi1/104-7465461-2831967
lunarx
06-01-07, 09:05 AM
Guys, You can't compare any of those $8 chepo guages with the guage mentioned above.
That guage has a bleed valve for dropping pressures down.
However, because it is still a digital guage getting updated pressure readings as you bleed down to target pressure is a PITA.
I prefer these Longacre guages.
http://www.bakerprecision.com/longacr26a.htm
http://www.bakerprecision.com/images/50404.jpg
They have the bleed valve and you get instant readings (no waiting for digital crap to update and display).
I have one of each of the 2" models.
I'm going to pick up a 2-1/2" next for the longer hose and swivel chuck.
If you like digital go nuts:
http://www.bakerprecision.com/longacr26.htm
http://www.bakerprecision.com/images/50380.jpg
nikon
06-01-07, 11:51 AM
I have that one too, and yes it does match the in-dash perfectly...thats why I bought their upper end model.
V-Max
06-01-07, 02:16 PM
Analog are just as accurate until they are dropped too many times. :)
Norm
nikon
06-01-07, 04:34 PM
^^and mine usually stay in the spare tire well in the trunk, so they get beat to hell.
Jschmank
06-01-07, 07:41 PM
I dont know about you guys, but if the dash says 30 lbs I am good. If its high, I let some out, if its low I put some in.
