AJxtcman
05-31-07, 10:44 PM
I missed this question a few years back on a semi annual exam.
The question read some thing like this.
On an 03 Escalade is the pistons OD bigger than the Cylinders ID?
I got it wrong.
The information is stated in the following area.
New Product Information
The purpose of New Product Information is to highlight or indicate important product changes from the previous model year.
Changes may include one or more of the following items:
Torque values and/or fastener tightening strategies
Changed engine specifications
New sealants and/or adhesives
Disassembly and assembly procedure revisions
Engine mechanical diagnostic procedure revisions
New special tools required
A component comparison from the previous year
Disassembly and Assembly Procedure Revisions
For certain applications, a spacer plate has been added between the flywheel and rear of the crankshaft. It is necessary to remove the spacer plate prior to removal and installation of the crankshaft rear oil seal and clutch pilot bearing.
The piston, pin, and connecting rod are to be serviced as an assembly.
Newer design pistons have a graphite coated piston skirt. The coated skirt outside diameter (OD) may be slightly larger than the cylinder bore inside diameter (ID) and the piston assembly may have a slight interference fit to the cylinder bore during initial installation.
I got it wrong.
