tbyrne
05-31-07, 10:26 AM
Wilwood Brake Sale
Truck Kit Features:
Big Brake Truck Front Hat Kits are engineered for use in conjunction with OE front hubs on a variety of competition, show, custom, and sport driving applications. Forged TC 6 piston calipers, Wilwood brake pads, machined aluminum hats, and 16" GT directional vane rotors exemplify award winning style and provide the ultimate in Big Brake Truck stopping power. Born from Wilwood's 25 year tradition of building championship brake systems, TC Big Brake kits are the perfect compliment to wheel, tire, and suspension equipment upgrades.
http://www.tbyrne.com/GTO/wilwoodlogo1.gif
http://www.tbyrne.com/trucks/Wilwoodtruck_SML.jpg
Forged Billet TC 6 Piston Calipers Calipers Available in Black or Red:
Superior strength forged billet calipers resist deflection under load without adding unnecessary weight. Six stainless steel pistons generate high clamping force and balanced pad loading while resisting corrosion and reducing heat transfer from the pads. Standard kits include black calipers with the Wilwood signature. Red calipers available on custom orders.
Staggered Vane Directional Rotors
Staggered direction vane rotors offer the highest cooling efficiency by maximizing the surface area and air circulation between the rotor faces. SRP series rotors are drilled and slotted, and then finished in a silver zinc wash to enhance pad performance and give that high tech, corrosion resistant look inside the wheels. GT series rotors are face slotted to enhance pad performance and carry the maximum rotor mass for thermal stability in high temperature or competition applications.
Forged Aluminum Rotor Hats
High strength forged aluminum hats are rib reinforced to carry extreme loads and eliminate unnecessary, power robbing rotational weight. Black anodizing prevents oxidation while adding to the custom look inside the wheel.
Wilwood Brake Pads
Advanced formula high friction compounds have quick response, big stopping power, and extended fade resistance over OE compound pads. Low dust, low noise formulas are easy on the driver and the wheels.
Mount Brackets and Hardware
Race proven radial caliper mount system with brackets and premium grade studs, nuts, bolts, washers, and alignment shims assure an accurate and secure installation.
Plumbing
Fittings and hoses for most kits must be ordered separately. Hose kit part numbers can be found next to each kit in the ordering information.
TBYRNE Motorsports carries the complete line of Wilwood Brake products and we're offering deep discounts for all of they packages. Cars, trucks... it doesn't matter! Pricing is lower than we are allowed to advertise but you can give us a call or e-mail tbyrne@tbyrne.com to receive a quote.
Part numbers and info can be seen on our website. Packages that aren't on our site yet can be seen on http://www.wilwood.com/"]Wilwood's (Wilwood's) website.. Please let us know what kind of vehicle you would like to put these on when you contact us. Part numbers are helpful too! :)
Have a good day!
Truck Kit Features:
Wilwood Brake Pads
Plumbing
Have a good day!
