: Why do the tow ratings differ on the website and manual??
teutonictrio
05-30-07, 03:56 PM
On Cadillac's website, the RWD model is rated at 8000lbs towing, and the AWD model at 7700, but in the manual, it states that the RWD is 7400lbs and the AWD 8100lbs - HUH????
I got the RWD model because it had greater tow capacity, but the manual states it it not only less, but less even than what the low end states on the website! :thepan:
hcvone
05-31-07, 05:56 AM
All the things I have seen rate the RWD to have more towing weight, it's not much different, but all RWD will tow more weight that an AWD. :)
teutonictrio
05-31-07, 09:47 AM
That's what I see everywhere too, on all vehicles (Ford, Nissan, Chevy, GMC) so why would this one say something else? Now it's got me a bit concerned. The AWD is definitely heavier and that ALWAYS reduces the towing capacity, yet...
teutonictrio
08-28-07, 11:00 PM
Bump...
Anyone know this? This still confuses me...
El Duderino
08-29-07, 01:38 AM
Don't know the answer, but I have the same question. My GMC Yukon Denali is AWD, and I have started looking at the Escalade to replace it. My front differential started whining at about 60,000 miles. The heaviest weight I tow regularly is about 3500 lbs.
BTW Teutonictrio, PM me when you get a chance.
Thanks,
El Duderino
hcvone
08-29-07, 06:24 AM
You have to change the gear oils in the front and rear diff more than the manual tells you to, that will make your diffs last longer, I never let them go more than 25k miles, and I use good synthetic oils, this will help make them last longer.
teutonictrio
08-29-07, 09:16 AM
El Duderino, PM sent.
Every other truck/suv out there has MORE towing capacity for the RWD than the AWD - every single one. The website states 8000lbs for RWD but the manual states 7400lbs for the RWD, which is not only less than AWD, but really freaking low.
El Duderino
08-30-07, 12:31 AM
Apparently I can't send or reply to PM's until I have 20 posts. I was just wondering where you guys ended up after the drama at that other forum. You can PM me, I can read them.
Thanks,
El Duderino
teutonictrio
08-30-07, 01:37 AM
Thanks,
El Duderino
We're all at www.thestyleofspeed.com - hanging out there instead! Come say hi
