Since there's been so many topics of A/C systems, maybe someone can help answer a concern of mine. My friend has an '83 Olds delta 88, and on that car there are manual controls for the A/C with MAX, NORM, BI-LEVEL, and VENT. Well, when you turn that A/C on, all the options blow through the floor vents, except NORM which blows out the dash. Is that a vaccuum line issue? I know this isn't a Cadillac where max and norm arn't an issue but it is a fellow GM cousin; can anyone help? Also it's a ban-new r134a sytem, everything under the hood works fine. Thoughts?
Mode delivery problems on those cars was always due to a vacuum problem.
It could be the vacuum supply system or an actuator vacuum motor problem.
Is that the big rear wheel drive car or the smaller front drive car of the mid 80's? I forget now.
At any rate, if you can get the control head out you can check the vacuum connection at the control head for supply vacuum.
I made a little tool that let me run vacuum to each "motor" individually and check them for leaks.
The vacuum switches used to break a lot too on the control, they can be serviceable if you can find the parts.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
