N0DIH
05-25-07, 01:32 PM
I have been wanting to be able to have multiple shift patterns on my ride, and I would like to be able to setup a economy/normal shift mode, a performance mode and a towing mode. Note. This might work on other 4L60E powered cars, but I do not have the specific info on them at this time, so I can't help right now. I do have the info for the 99-00 OBS (Old Body Style) Escalade and will post that info later.
A little background:
We have 4 shift modes on the LT1 PCM (94-95).
1. Normal Mode - This is your mode that is default when you start the car and you are in D4/OD mode (Overdrive).
2. Manual Mode - This is triggered if you have the shifter in D2 or D1.
3. Performance Mode - This is triggered if you have a performance mode switch and you have started the car and flipped the performance mode switch (F and Y car only)
4. Cruise Mode - This mode is active when you have cruise control on
Ok, what can we do?
1. We need to add the Peformance Switch modification that Scott Mueller has written up.
Adding an automatic transmission "Performance Mode" switch to B/D/F/Y vehicles with an LT1 engine and a 4L60E (RPO M30) automatic transmission:
Copr. 2005 by: Scott Mueller <mailto:scottmueller@compuserve.com>
Photographs courtesy of Jay Gottlieb.
1994 and 1995 Pontiac Firebirds equipped with the LT1 engine and a 4L60E (RPO M30) automatic transmission also came with a very cool feature, a transmission "performance mode" switch (button) mounted in the center console. The switch is labeled "Transmission - Perform" (the lettering is backlit in red), and functions like an electronic on-demand shift kit. When in performance mode the shifts are firmer and upshifts are delayed so they occur at higher engine rpms.
The switch is a simple momentary contact push-button switch which is wired to the PCM and mounted in an attractive gray bezel. There were actually two switches available, one has two buttons, a "Transmission - Perform" button and a "Traction Control" (RPO NW9) button, while the other has only the "Transmission - Perform" (M30 w/o NW9) button. It is the latter one you would want when retrofitting to any vehicle without traction control. Note that 6cyl Firebird models also had a similar switch, but it was used to activate 2nd gear start mode instead and of course had different labeling.
This button can be easily installed and made functional in any '94-'97 LT1 equipped vehicle (including the B-car Impala/Caprice), provided you are using either the '94-'95 F-car PCM or you have the performance mode shift subroutine installed in your existing PCM by somebody like Ed Wright of Fastchip <http://www.fastchip.com>. For example this button could easily be added to a '95 Camaro with no PCM changes whatsoever, as all F-cars for a given year use the same PCM calibration (although the Camaro never included the performance mode switch). It could also be added to any '94-'96 Impala or Caprice, provided you had Fastchip install the proper subroutine in your PCM. Wiring the switch is simple, there are three connections made under the dash and two wires that run to the PCM.
The performance mode switch enables the selection of a more aggressive shift pattern when operating between 40% to 100% throttle. When performance mode is selected, the B+ performance mode signal from the PCM is momentarily grounded (the PCM sees the signal go to 0 volts). The PCM then enters performance mode and turns on the performance mode indicator LED inside the switch button. While in performance mode, shifts are firmer and delayed 1-3 mph on upshifts as well as advanced 1-3 mph on downshifts. Normal mode is selected by momentarily pressing the performance mode switch button again. Normal mode is also the default anytime the ignition switch is cycled.
If you have the 13 photos (PM01.JPG through PM13.JPG, thanks to Jay Gottlieb) that go along with this article, they show the installation process as well as the completed result.
(NOTE: I don't have the photos, I will talk to Scott about getting them, but they are lost on the net right now--Tom, N0DIH)
To install and connect the performance mode switch you will need:
Part no. Description Qty.
10195551 '94-'95 Pontiac Perf. Mode switch (M30 w/o NW9) 1
12064769 10-way female Metri-Pack 150 connector housing 1
12047767 Female Metri-Pack 150 terminals 5
12084913 Female PCM connector terminals 2
12051375 1/4-inch wire conduit (15-feet) 1
If you can't get the individual 10-way Metri-Pack 150 female connector housing
and terminals, then instead you can purchase a pigtail instead:
12101762 10-way female Metri-Pack 150 connector pigtail 1
In addition to the parts above, you will need three approx. 6-foot lengths and two approx. 20-foot lengths of 22 gauge wire, plus a number of nylon zip ties to secure the wiring.
Although I'll tell you everything you need to know in this write-up, for further reference you will find the wiring diagram for the switch on pages 6E3-C8-12 and 8A-39-2 of the '95 F-car service manual. The connector pinout is shown on page 8A-202-21.
The 10-way connector for the switch is wired as follows:
Terminal Signal
Position Description
A PCM A15 (red connector) Perf. Mode LED indicator driver
B Interior lights dimming
F Ground
G B+ Hot in Run (ign. switch)
K PCM C13 (gray/clear connector) Perf Mode switch signal
The connector terminal positions facing the connector female end with the retainer lock on top are shown in the following diagram (view in a monospace font):
__
_| K J H G F |
| A B C D E |
Note that only 5 of the 10-way connector terminal positions are used.
Operation is as follows: When the performance mode switch button is pressed, it internally connects terminal K (PCM C13) to F (ground), which tells the PCM to enter performance mode. The PCM will then ground terminal A (PCM A15) which causes the LED inside the button to illuminate indicating performance mode has been selected. Power for the LED is provided on terminal G (B+ Hot in Run). Terminal B (Interior lights dimming) provides power for the red backlight inside the switch circuit.
Installation:
Locate a position where you will install the switch. Remove the console cover if you intend to install the switch there, or if you wish to put it in the dash, remove whatever dash piece it will be installed in.
Get three 6-foot lengths of 22 gauge wire and crimp Metri-Pack 150 terminals on one end of each of the wires. Although specific colors are not required, if you are a perfectionist like I am, they would have to be GRY (gray), BLK/WHT (black with a white tracer), and BRN (brown) because that's exactly what the factory used. <g>
Insert the terminal ends you just crimped into the B, F, and G positions (respectively) in the 10-way connector. Route the wires through the place you intend to install the switch (for example the floor console) to underneath the left side of the dashboard. Splice or connect the wires to the appropriate connections under the dash such that terminal B is wired to the vehicle interior lights circuit, terminal F to ground, and terminal G to an ignition (hot in run) source. Normally GM vehicles use GRY for interior lights, BLK/WHT for ground, and BRN for ignition (hot in run) connections, so you you can probably look for any wires of those colors under the dash and splice to them. Be sure to verify the circuit you are connecting to before splicing.
Next get two 20-foot lengths of 22 ga. wire. Although it's not mandatory to use specific colors, the factory used DK BLU (dark blue) and LT BLU (light blue) for these. Crimp Metri-Pack 150 terminals on one end of each of these wires and insert them into the A and K terminal positions (respectively) of the 10-way connector. Then route these wires to underneath the left side of the dashboard, and then through the firewall and over to the PCM.
On the B-cars, there is a convenient oval shaped hole with a rubber plug in it just behind the LH front wheel arch, which will allow you to route these wires through the firewall without drilling any holes. Get the wires positioned and tied down under the hood, it is recommended you either insert them in existing harness loom, or use the 1/4-inch loom I listed above to protect them. Make sure the wires are tied down and secure all the way to the PCM.
Trim the wires to length and crimp on the PCM connector female terminals. Then insert the PCM terminal ends into the PCM connectors at the A15 (DK BLU wire from terminal A on the 10-way switch connector) and C13 (LT BLU wire from terminal K on the 10-way switch connector) respectively.
Finally cut a hole matching the backside of the switch in the console or dash area you intend to mount the switch, then plug the 10-way connector into the switch and snap the switch into place. That completes the wiring!
If you are not running a '94-'95 F-car PCM, then you will want to talk to your favorite PCM reprogrammer to have the performance shift subroutine installed in your PCM. Ed Wright of <http://www.fastchip.com> can do this as well as customize other aspects of your PCM. Once the PCM with the proper subroutine is installed in the PCM, the button will be fully functional.
I had this switch installed and functional in the center console of my Impala since early '96 (using an F-car PCM calibration). It gives all the effects of having a shift kit installed when activated, and yet with the press of a button one can return to normal softer shifting. All in all this is another great "factory" mod one can add to their car! Scott.
Ok, what can we do?
Terminal Signal
F Ground
__
_| K J H G F |
| A B C D E |
Installation:
