View Full Version : Signal Mirrors on my 02 Lade
SteveSkal
05-21-07, 10:06 AM
Hey all, what do you think of this deal I got for both sideview mirror glass (heated with signal) on E-bay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=020&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=300111397628&rd=1,1
$165 shipped. Anyone else do the upgrade to the signal mirrors, how hard was running the wires to the turn signals? I'm looking forward to this upgrade, it not only looks good but good safety upgrade!
SteveSkal
05-22-07, 04:23 PM
What's the matter, NOBODY on this board has ever put the signal mirrors on their Escalade's?????
Synergetic
05-22-07, 05:02 PM
Yes, they have. Do a search and you'll see.
DLE
05-22-07, 05:13 PM
A quick search always does the job. :thumbsup:
http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum/95982-03-06-mirrors-02-a.html?highlight=signal+mirrors
Playdrv4me
05-22-07, 10:08 PM
What the heck... were the signal mirrors standard equipment in the 03's or not?
Their product listing says "Standard 2003-04". Mine doesnt have them.
slk230mb
05-22-07, 11:05 PM
I thought they were stock on 2003s. Maybe pull the glass off and see if you have the extra wire in the housing for them?
Playdrv4me
05-23-07, 12:33 PM
Yea Im curious now. Wouldnt really surprise me if they were maybe stolen during the theft and then replaced with the standard 02 mirrors due to cost, but the wiring should be in there or at the pigtail on the truck if so.
SteveSkal
05-23-07, 01:07 PM
If that's the case that would make for an easy swap, thats my biggest concern is the wiring aspect of it, if yours are already there you can plug in and be done. I'm having an alarm system installed in the next week or 2 so maybe I'll ask the installer to run the turn signal wires into the door and leave some slack so when I change the mirror glass I can just run it into the housing.
zerocarpileup
04-16-09, 02:51 PM
you have to actually disassemble the entire mirror to do it properly, you need to run a power and ground through the actual motors then run them down the same loom that the other wires are in. if you dont run it through the motor,you will be forced to run the wire elsewhere and anywhere else the mechanism of the power fold mirror will snag and chafe the wire and eventually short out. once you get it through the motor and rubber door loom, then just go under the dash remove the knee pad if you have to and connect the left driver signal to the light blue wire in the orange harness all the way to the left and the right passenger goes to the royal blue wire in the same orange harness. seal it all up and your done. the orange harness im speaking of is directly in front of the diver and is part of a 3 or 4 harness box, the one all the way to the left is the orange harness.
zerocarpileup
04-16-09, 05:29 PM
you have to actually disassemble the entire mirror to do it properly, you need to run a power and ground through the actual motors then run them down the same loom that the other wires are in. if you dont run it through the motor,you will be forced to run the wire elsewhere and anywhere else the mechanism of the power fold mirror will snag and chafe the wire and eventually short out. once you get it through the motor and rubber door loom, then just go under the dash remove the knee pad if you have to and connect the left driver signal to the light blue wire in the orange harness all the way to the left and the right passenger goes to the royal blue wire in the same orange harness. seal it all up and your done. the orange harness im speaking of is directly in front of the diver and is part of a 3 or 4 harness box, the one all the way to the left is the orange harness. i have a full instructional illustration with pictures in a PDF file but i am exceeding my file size limits. if anyone wants to receive it and post it for the forum just let me know, it would be a great sticky.
ZaC851
04-16-09, 08:52 PM
how big is it? I will get it up somehow
zerocarpileup
04-16-09, 09:08 PM
The PDF file is 1.36 MB, how do you want to get it up?
ZaC851
04-16-09, 09:14 PM
oh thats it?. go to www.megaupload.com and upload it there and paste the link for everyone here. That would be the easiest
ZaC851
04-17-09, 06:48 PM
Heres the manual to download.
http://www.megaupload.com/?d=9AOW449O
