View Full Version : 1984 fleetwood 500
cadillacdeville
05-19-07, 07:42 PM
Is it possible, with out to much modification to put a cadillac 500 in a 1984 fleetwood.
The Ape Man
05-20-07, 09:28 AM
That all depends on your definition of too much modification.
drmenard
05-25-07, 11:24 PM
you can put a 500 in your 84 fleetwood ... It is a bolt in...All the parts can be taken off a 77-79 full size RWD caddy...It would be best to use a TH400 transmission... you can use your rearend with a little drive shaft work, but maybe best to use a rear off a donor car..If you get youself a donor car everything you need is there...when you take out the computer , all you have to do is ground one wire and the climate control will work just fine...
Wheelman322
05-25-07, 11:33 PM
...all you have to do is ground one wire and the climate control will work just fine...
Just curious if this means I can add an electronic control head to my 78 if I ground this wire?
