View Full Version : Accessing the OBD2 in your caddi
gspencer914
04-28-03, 12:03 AM
If you dont know by now this is the correct procedure for accessing the On Board Diagonstics on your caddi. This is really simple and takes very little time. First thing is to locate the two buttons on the right of the dash marked info up and down and the on/off button. Hold down the on/off button and push in the up or down arrow. Your dash will get really bright and you will be in the OBD. from there you can retrive codes and check status on all the systems. If you do it with the car not running you will see codes. Better to do it with the car running. You can also from this OBD remove codes where your service engine soon light or check engine light comes on. If you need a code defined just let me know I need the letter and numbers of the code and I can give you the problem. Any other questions let me know.
Happy diagnosing
George
mnymaker
05-05-03, 09:14 AM
Thanks for the tip. I did this on my 99 Seville SLS and received the following codes:
AMP U1064
DDM U1301
What exactly do these particular codes mean? I looked up the definition to the codes on the internet, but they don't explain what the problem is or could lead to down the road.
Thanks
Devil_concours
05-05-03, 09:24 AM
on/off button?
does this apply to my 97 deville concours?
gspencer914
05-05-03, 07:01 PM
Originally posted by Devil_concours
on/off button?
Dont know. Do you have 3 buttons on the right side of your instrument panel? The right and left buttons will give you the same result.
gspencer914
05-05-03, 07:03 PM
[QUOTE]Originally posted by mnymaker
[B]Thanks for the tip. I did this on my 99 Seville SLS and received the following codes:
AMP U1064
DDM U1301
Before I get into these codes more in depth, was the car running when you pulled them?? If not please do it again and then see if they are still there. I know what they are and i can explain them just let me know
mnymaker
05-09-03, 08:26 PM
Yeah the car was running at the time I pulled them
Thanks
gspencer914
05-11-03, 03:09 PM
mnymaker,
Here goes. U1064 is Loss of Communications with DIM. Sounds pretty complicated Right.
Here’s the explanation. U1064 is a loss of communication with the Dash integration module (DIM). It’s in history. You can clear it and it might come back. It’s really just a code where the Body control module tries to communicate with the DIM. There are a number of reasons that it couldn’t. 1 is something else was communicating at the same time the BCM was talking to the DIM. Also if the BCM was calibrating and the dim was performing another function this will throw the code as well. It doesn’t become a problem unless it comes back again and again.
Here’s the other u1301 Class 2 BUS shorted to voltage.
This code only sets if the B1982 or B1983 is not current in module memory. The module detects that the Class 2 serial data line is shorted to battery for at least 2.6 sec. It’s about the same as the last one. It takes 50 consecutive ignition cycles if the conditions for setting the DTC are no longer present. You can also clear this one and see if it comes back. If not no problems. If so then you'll need to take the car into the dealer for a Body Control Module test. Hope this helps if you have any other questions let me know.
George
mnymaker
05-11-03, 06:15 PM
thanks.... I only cleared it once and it came back, but I havent cleared it again yet so I will try that and let you know
Devil_concours
05-11-03, 11:29 PM
i just hit info into something that i can't reset. then press and hold info reset button for a little bit. It will tell me whether all monitored systems are working properly or not.
HOWEMOTORSPORTS
05-21-03, 04:07 AM
can you help me with the AO10 code on my 93 sts with a N*. I have found nothing on it.
Katshot
05-21-03, 08:43 AM
That's your outside air temp circuit. It usually means the sensor is bad or disconnected. I believe on your car it's located behind the grille.
