: 02 Deville Overheating
THE VILLE
04-20-07, 07:55 PM
i KNOW THIS HAS BEEN TALKED ABOUT A MILLION TIMES BEFORE BUT NONE ARE TOO SIMILAR TO MINE OKAY HERE GOES I GOT AN 02 DEVILLE BEEN OVERHEATING JUST GOT A NEW THERMO AND NOW ONLY OVER HEATS WHEN DRIVING I COULD SIT IN THE CAR FOR HOURS IN PARK AND IT WILL STAY AT NORMAL TEMP BUT AS SOON AS I DRIVE IT WILL HEAT UP QUICK IF ANYBODY HAS ANY CLUE AS TO WHATS WRONG PLLEASE LET ME KNOW JUST FLUSHED THE COOLANT WITH TABS AND OIL CHANGE OH YEAH IF ITS OVERHEATING AND I PULL OVER AND REV THE ENGINE A LITTLE THE TEMP WILL GO BACK TO NORMAL PRETTY QUICK THANKS
JimD
04-20-07, 07:59 PM
Water pump drive belt, or belt tensioner, or both.
THE VILLE
04-20-07, 08:22 PM
So Pretty Much Easier To Replace The Whole Water Pump
Ranger
04-20-07, 08:56 PM
No, just check the belt tensioner to be sure that it is not rusted at the pivot and not providing enough belt tension, thus causing the belt to slip and the pump to turn slower.
Caddys 32
01-23-12, 11:43 AM
my 02 deville not over heating but just replaced the tensioner cuz it was make n knock n noise but it wasnt bad but bearings were make n some noise so it did need a new pulley. the main knock n noise was come n from the water pump, ordered it off line 4 $25 n free shiping so just wait n 2 get it then mec. put n it on 4 $110 sounds like a good deal said it will take like 2 hours 2 do. n im go n 2 have him put new thermastat on 2 while85441 every things apart.
postman2000
01-23-12, 01:25 PM
My 2000 Deville was acting very similar..It would be fine if it was idling in park..But as soon as soon as I would start driving it would rapidly start over heating..Turned out that it was the head Gasket/ Head Bolt issue..I guess when idling the pressure wasnt enough for the engine to "pop its top" But as soon as I would get on it and drive it the overheating bells would go off and everything...Change engine oil message would come on..And by this time I had already replaced the radiator, radiator cap, overflow jug, water pump and belt, thermostat, radiator hoses, coolant sensor and I also cleared all my coolant purge lines..So my biggest fear had come true... I hope it is not your head gaskets..But I have come to realize with these motors hope for the best but expect the worse...Good luck..Check your coolant purge lines..it cant hurt..it may not help but wont hurt to do..
Sorry..I just realized i responded to a 5 year old post...:cookoo:
