View Full Version : '98 Eldorado codes
kisam
04-19-07, 01:11 PM
The engine dies at idle and while driving but starts back up? I am thinking it is the Camshaft sensor but would like your opinions:
Codes
PO372
PO463
PO603
PI1377
PI1599
B1327
B2120
Thanks,
Kathy
Ranger
04-19-07, 04:23 PM
P0372 - IC 24X Reference Circuit Missing Pulses
P0463 - Fuel Level Sensor Circuit High Voltage
P0603 - Control Module Long Term Memory Reset
P1377 - IC Cam Pulse To 4X Reference Pulse
P1599 - Engine Stall or Near Stall Detected
B1327 - Vehicle system voltage below 9.0 volts
B2120 - Lumbar Up/Down Sensor Failed
These cars have a lot of electronics in them and do not respond well to low voltage. I'd have your battery checked before you do anything else based on those DTC's
For future reference, you can find the DTC definitions here. http://myweb.accessus.net/~090/dtcobd2.html
MWA
04-20-07, 08:20 AM
Had the same problem and the Ranger is absolutely correct. Once I put a new battery in mine and then cleared the codes, only the lumbar and a fuel sensor guage returned. Also had a problem with small amount of leakage around the positive side terminal of old battery.
