Brother_B
04-14-07, 04:54 PM
I am wordering if my timing is out 180 degrees. When the timing mark is pointing at the 0 degree notch, is the distributor rotor _definitely_ supposed to be pointing at the #1 spark plug, or is this only true half the time, and the other half of the time it should be pointing at #4? I have heard of people installing distributors out by 180 degrees. How does this happen, and how can I check for it. Car won't start after replacing distributor, and I suspect the timing is way out. I am going to bump the starter until the timing mark mis lined up with 0* and see where the rotor is pointing and twist the distributor to line up the rotor with #1 when I try to start it. Sound right? Also is it true that it is easier to start a car when the timing is slightly retarded as opposed to slightly advanced?
Thanks y'all
Thanks y'all
